Question about HP Pavilion dv4000 Notebook
Pavilion dv4000 microphone
Thanks for your help re: the microphone. I plugged it in, but no volume. Where do you adjust the volume control for the microphone? Is it on the desktop somewhere? Thanks again for your quick reply, Annika
i have checked evrythng bt stil dere iz no sound.
how can i repair it at home.
i don evn knw dere r inbuild microphones or not in ma hp dv4000.
please email me the solution / info - k_sehrawat@yahoo.com
  • Anonymous May 11, 2008
    no sound
Shaguftakaslam@yahoo.com
my laptop hp pavillion 4000
in this laptop no sound driver plz
Posted on May 31, 2008
There is no option to set up karaoke, ive tried everything
Posted on May 04, 2008
    Sergeant:
    Champion:
  • 256 Answers
Sorry no build in microphone use ext....
Posted on Apr 28, 2008
When I use my headphones for skype of my Pavilion dv7, the microphone dosn't work. Why???
Assuming that the microphone jack is correctly connected, go to sound properties in Control Panel and check that microphone is checked and that the volume is correctly adjusted.
Hope this helps
May 09, 2011 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
Just purchased Samson dynamic microphone. Can we use this with a portable stereo or computer? If yes, how does it work? What do we do to set it up?
You can use it with a portable stereo that has a microphone input socket - just plug it in. You may need to adjust a mic volume control - this will vary from one system to another.
With a computer just plug it onto the microphone input socket (usually colour coded red or pink)
You will also need to enable it in 'control panel' - see below.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 14, 2011 | Samson Dynamic Vocal Microphone
Hi, My microphone inside the computer does not work.....please help as i keep having to use a usb phone all the time...many thanks
Not sure what operating System (windows version) you have on the PC
some suggestions for Vista
control panel> classic view> sound> You have a TAB now called recording>If a microphone listed there click on it > Properties button at bottom of screen > New box opens with various tabs> Levels Tab> Microphone volume and mute there > Make sure its full volume and not muted - the image at the end of the volume control - click onit to mute / unmute
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Pavilion dv4000 Notebook
Whenever i use software like sype to make internet calls it keeps telling me my microphone volume is low. i then ran the test hardware wizard for my sound and the microphone does not pick up any sound....
Try adjusting the volume settings in your mic.
Go to Start->Control Panel->Sounds and Audio Devices-> Click on Voice Tab->Voice Recording ->Then adjust volume
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Headset microphone will not work on my hp pavilion notebook
The in-/outputs may not be turned on at this time. Either check your settings in the Control Panel, Sounds and Audio devices or, if a small speaker is shown on the right of your toolbar below, double-click this to open the sound control panel.
Mar 21, 2009 | HP Pavilion dv4000 Notebook
Hi Annika,
The setting of Microphone Volume depends on whic is your hardware and which Operating system you are using. Also in which software you are trying to use.
I am describing here a general way how to addjust microphone volume
  • See the following pic:
  • The above picture is from my icon tray, you can find it on your right-bottom of the screen.
  • I have marked two icons the first one (left) is for Realteck as its my audio device, the second (right) is from windows and its avail in all windows operating system.
  • So just double click on Volume icon (right one).
  • It will open a window like:
  • Click on option and select properties
  • Then click on Recording and then on ok button as follows:
  • Then a window will appear with all audio input devices you have on your system, If there are more than one then select microphone.
  • Addjust your volume as per your need.
  • and finally...............:))
If any problem just Ask me.
Gud Luck
Iqbal
Apr 16, 2008 | HP Pavilion dv4000 Notebook
Pavilion PC Notebook Verve dv2000 Microphone
yaa you have to set your microphone valume but first check if you are getting right connection.
In front panel jac there are three Jacks
  • The Left on is for microphone, i.e. you should insert the microphone node in it.
  • The second 2 jacks are for speakers you can insert speaker node in any one or both.
Try this I think it will work, otherwise ask me and let me know whats going on.
Gud Luck
Iqbal
HP Pavilion dv4000 Notebook Logo
657 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
