Mod rt700 was adjusting vol and screen went blank I have sound but no pic.
  • 1 more comment
  • rpm333 Apr 28, 2008
    Taught you were Curtis Electronics. This is a 7" LCD TV Mfg. by Curtis TV Div.
    Curtis MFG. 7" LCD tv.Mod. rt700
  • rpm333 May 05, 2008
    First thing I did was to turn off RT700 over night did not reset it self.
  • 535 Answers
See manual or chak the all the connection see for loose connection
Posted on Nov 05, 2008
    Brigadier General:
  • 3,614 Answers
Unplug the unit from the electrical outlet.
check all the connections.
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 28, 2008
  • Maanita Chadha
    Maanita Chadha Apr 28, 2008
    Turn the power off completely unplug from the power source and leave it turned off for 2hrs then turn it back on it should resolve the issue and update me abt the same
Toshiba TP50f50
unplug the set for a half hour and start over. As long as you did not save the settings, all should be ok.
Sep 14, 2007 | Toshiba 50H13 50" Rear Projection...
The screen on my Vizio television went blank. The
if you was trying to wipe your tv off with glass cleaner are something that can make your tv go to a black pic
Sep 22, 2009 | Vizio L32 32 in. LCD HDTV
Blue color
On front bottom panel remove behind it will be your focus/screen block cobtrol adjust Blue screen drive and focus also how to enter service mode for convergence with set off PRESS and hold at same time ch-&vol- untill set comes back on release you should now be in service mode for convergence.
Feb 19, 2009 | RCA D52W19 52" Rear Projection Television
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
The image changed after putting it in the computer
sounds like a white balance problem! go into menu to adjust white balance
Dec 07, 2008 | Cameras
Blank Screen
Many have replaced caps on the SMPS board, with success:
2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 100μF 25v
Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Once you get it on, there are adjustments to the VS voltage to cure the speckle.
Jul 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Tv pic went blank but still have sound?
gud day..ur tv needs a qualified serviceman.. maybe in the video setion of the PCB theres a coroaded solder..you need a soldering iron and lead to reinforce the coroded terminals..ty
Feb 05, 2008 | Zenith R40W46 40" Rear Projection...
Hitachi screen went blank?
1) Consult service manual for details.........procedure issues?
Sounds like the digital convergence unit got confused....
You may have to start all over again at default....
2) When converging a PTV, less is better ( adjustments) unless
you are positive adjustments will yield some improvement..
3) Info source = www.HitachiServiceUSA.com
Please rate this solution.............................
Nov 03, 2007 | Hitachi 43FDX01B TV
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
