Question about Cell Phones
When turn on the phone only a white screen shows and vibrates once press the on button and only vibreates so cannot use the phone or acess anything just a plain white screen
  • 2 more comments
  • bernardchan Apr 28, 2008
    when turn on the phone only a white screen shows and vibrates once press the on button and only vibreates so cannot use the phone or acess anything just a plain white screen
    sony ericcson k800i
  • ic3ic3baby Jan 04, 2009
    u have the same prob.. k800i help pls!!
  • Anonymous Apr 06, 2009
    white screen all functions ok
  • taylorpriest May 18, 2009
    i have an LG Chocolate and the same thing happened to me what do i do?!?!
    Sergeant:
    Champion:
  • 283 Answers
What is the brand of phone you have generic says here, need to know
Posted on Apr 28, 2008
How do I turn off battery on Xperia T that is built in
I'm 100% sure on the Xperia T(I have a ZL) but with most off the Xperia's there is some sort of removable back panel or a hinged flap that opens up under the panel/flap there is a orange button that you will need a pen to press and hold. hold this button down while holding down the power button it should vibrate once, keep holding the buttons then it should vibrate 3 times, now let go of the buttons and your phone should stay off.
Aug 17, 2014 | Sony Xperia U ST25I Android OS v2.3...
Lg g2 will not turn on
  1. Take your phone and turn it off - just press power button and select "power off".
  2. Wait while your device is shutting down.
  3. Then, press volume down button and power button together until the LG logo appears on the screen.
  4. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
  5. Once you do that, on your LG G2 the factory reset menu will be displayed.
  6. Press power button in order to agree and wait while the hard reset is being completed.
Jun 09, 2014 | LG G2 White for Verizon Wireless CePhone
My sonyericsson xperia x-10i won't turn on on pressing power button all it does is vibrate once and then there is white screen which blinks after some time. am also not able to charge the phone nor switch...
Plug phone into charger then follow directions below:
1.From the Home screen, tap the applications bar.
2.Tap Settings > SD card & phone storage > Factory data reset.
3.Tap Reset phone.
Feb 03, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My nokia 3110c shows only nokia logo and after that only white screen . please help me what is the problem
follow these steps:
1) remove the back case 2) press the power on button 3) remove the battery (button still pressed) 4) insert the battery (button still pressed)
repeat 2-3 times, this will solve the issue...
if it helps plz vote it
Jan 16, 2011 | Nokia 3110 Cellular Phone
The phone does not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times before switching off.
your phone got deads its happens many times when firmware is not properly updated,try to update your phone firmware but be care or send it to nokia centre
Sep 06, 2010 | Nokia X3 Cell Phone
White screen on my phone
Its WSOD (White Screen of Death)
The Most Common Problem for SE-Walkman Phones.
There are tested/working ways to work it out.
You have to flash your Firmware, BUT read the full procedure first and ask me if you got any problem, before proceeding.
The Tutorial goes here
Note: This solution will ONLY work if your Phone shows a pulse of vibration when turned on.
Regards, Waqar.
Sep 23, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Freezing, flashing backlight on and off, vibrates
my w900i turns on, and can charge. just got re-flashed from a white screen of death. now every time i try to acess something on the phone such as a midi file or the master reset, it freezes and the back light flashes on and off and the phone vibrates. is this a software error? does it need to be reflashed?
Apr 08, 2009 | Sony Ericsson W900i Cellular Phone
Can't turn off the mute on my phone
I have the same phone, when you close it with the camera facing you you will see the two buttons on the left side. One is long (on top) and the small one is on the bottom, or under neath it. You press the long putton which is above and you should see the word STYLE: followed by either "Silent" " Vibrate" "Loud" etc. Once you have pressed the skinny long button on the left side and the screen says STYLE: silent then you press the little button below it once, then press it again, etc it cycles through the different ringing modes like silent, vibrate, vibrate then ring, soft, and loud. You press it until you see a setting you like and then press the long skinny button on top to set it. I keep mine on Loud. I hope this helps.
Jun 10, 2008 | Motorola Mobility E815
W220 display problem
just open the handset and remove ur board frm it and wash it with white petrol and dry it with ur hairdryer. reply me
Jun 05, 2008 | Motorola Mobility W220 Cellular Phone
Phone acting up - screen problem
see if i can help you here on the white screen go to main menu...settings.....personalize......wallpaper you will see picture next ....is it set to none? you can set a wallpaper here. on the vibrate.....main menu...settings....ring styles... is it set on just vibrate? you can change it here to different settings....vibrate....soft...loud...vibrate and ring so if it just says vibrate u can change it there. mine is set on vibrate and ring...down below that you will see vibrate then ring details...here u can choose the ringer u want plus ringer volume and different settings. hope this gets you back what u wanted. jeff
Oct 01, 2006 | Motorola Mobility E815
Cell Phones Logo
237 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
