Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
221 GB Free on MyBook - Error states not enough space for backup
I get an error every morning stating that there wasn't enough space for the backup. My Windows XP desktop has 134 GB total harddrive (under My Computer, anyway) and 61.4 GB free space.
My Book shows 465 GB Total Size (again, in My Computer) and 221 GB Free Space. It has run backups before - so this should be updates to that backup.
I must have the settings wrong. MyBook will accept drag and drop updates - but says it doesn't have enough space for the nightly automatic updates.
I'm hoping there's a common error I've made in the update selections - any thoughts?
Thanks in advance!
  • 2 more comments
  • pamms Apr 29, 2008
    That's a great thought - but, yes, it is already NTFS.
  • tqforest May 02, 2009
    I am trying to copy a few movie files to Mybook. The ones that are 2~4 GBs are copied over. However, my 7GB-long file keeps getting msg, "Cannot copy: There is not enough free disk space.
    That's not true. I've used up only 136GB of my total of 298-GB drive. I thought it needs defrag. But it does not.
    What happened?
  • shirl2sg May 11, 2010
    I turned off my computer, and it seems to be OK....my E drive My Book is still FAT32, so nothing changed. Elsewhere I had noticed that someone said you had to put volumn in someplace in the command. Please help. Thanks!
    When I did typed this in, CONVERT E: /FS:NTFS /X
    It then asked what was the volumn in E: I then put in /FS:NTFS /X
    Was this the correct thing to do? Will this change when I turn the computer off. So far E has not changed From Fat 32, or did I just mess up my computer. Now I'm worried.
    Thanks
Is the drive formatted as FAT32?
If so, and your backup is more than 4GB, it will not be able to write the file to the drive.
Open a Command Prompt (Start | Run | CMD) and at the prompt type:
CONVERT V: /FS:NTFS /X
Where V: is the drive letter of your My Book.
That will convert it to NTFS and it will be able to handle files larger than 4GB.
Posted on Apr 29, 2008
I have the same problem.
if i will do this command, will i loose my files in MYbook
Posted on Nov 04, 2008
2 Suggested Answers
SOURCE: 221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Posted on Dec 27, 2008
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
Error message states that there is not enough room
One possibility: you have too many files in the directory. USB flash drives are usually formatted in FAT32 and thus stuck with the limits of the standard. Try moving some of your files into folders.
Second check for a encrypted partition locking part of the disc. If ReadyBoost capable a section of the memory set aside to do ReadyBoost for Windows Vista or Win7 (you'll need to release the ReadyBoost on the computer that dedicated the space).
I hope this helps.
May 13, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Clarification re WD My Book storage space issue
this happen to a cousins laptop the only way to get it to sort out was to format the drive.it sounds harsh but it was the only way.
Dec 06, 2009 | Western Digital WDH1Q5000N 500GB MyBook...
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Do you know about computer GB free disk space
Yes. you have 221 gb available disk storage left. 5 gb will hardly make a dent in that.
You can right click on the computer icon and then select properties to view a pie chart representation of available space if that makes it easier for you.
Nov 02, 2009 | HP COMPAQ Presario SR5410F Pentium...
Space problem in Mybook
If the disc is formatted to FAT32. You will be limited to 4GB files. NTFS is limited to 16 exibytes. Which is huge even by todays standards.
May 02, 2009 | Western Digital My Book Essential Edition...
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Cant download large files to my book
The controller board in Mybook might not support files over 4 gb. Check with the manufacturer if there are any new drivers for you product to solve your dilema. You could also just buy a cheap external case for the drive in the mybook and swap it out. None of the new cases have these limitations and you can get them online for less than 20 bucks. I like MAD Dog cases myself. I hope this helps you.
George
Jul 15, 2008 | Western Digital 500GB My Book World...
Error Message
Remove the microSD card and then delete one or more files from the Sansa's internal memory to free up an additional 90MB.
Jul 02, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
City Navigator Lower 48 States NT 2009
Hello parteeboy24,
The on board memory in your Nuvi 200 may not have enough free space to hold the map. You may be able to free up some space by deleting maps or language packs that you don't use. (Be careful to back up any files you are going to delete.) Or you can add an optional SD memory card to the unit to increase the storage capacity on the GPS.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin nuvi 200W GPS Receiver
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
2,046 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
