Question about Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
A bad speaker
Anyone know who carries these speakers?
  • beddog May 10, 2008
    thanks Ken
  • 250 Answers
Hello beddog,
I would recommend contacting the manufacturer directly for parts. You can find their contact information through their website at:
Best Regards
Go Ahead. Use Us.
Posted on May 01, 2008
2 Suggested Answers
Agent Ken
  • 250 Answers
SOURCE: corba li 6000 speaker?
Hello beddog,
Best Regards
Go Ahead. Use Us.
My Roland Street cube amplifier has a bad speaker- where can I find a replacement speaker?
Rubber cement is an excellent for minor speaker cone damage but if you feel that a replacement is required, try MCM Electronics online. They carry lots-o-speaker replacements. Be sure to match wattage and impedance (ohms) of the speaker though as these are important spec's.
May 21, 2014 | Roland Cube-st Battery Powered Amp Cube...
HK395s Left speaker out. The speaker still works and the problem is on the little circuit board in the oppoosite speaker. Can anyone assist? It osn;t the wiring as I checked that back to the pin co
Did you check the input? as in the plug that goes into the computer itself? Try plugging it into something else like an ipod or other source to see if it works correctly. You've done great in checking it internally, and it's not likely that the circuit board would go bad...let me know
Sep 01, 2012 | Dell HK395 Computer Speakers
My altec lansing speakers BX1220 will not work with windows xp. it says there is no device. help
the usb cable is for powering the amp it does not carry audio, there's a 3.5 mm plug that connects to your sound card. also, no matter what anyone tells you, there is no driver download for these speakers.
Feb 21, 2010 | Altec Lansing BX1020 Computer Speakers
Only one speaker working on my str-de675 receiver
check your main board witch is under the powersupply. careful the caps hold charge and hurt really bad. check your digtal input board also.
Jun 02, 2009 | Sony STR-DE675 Receiver
My pioneer sx-315 audio reciever turns on for a few seconds and then automatically shuts off... Is there something wrong with the power supply? Does anyone have a schematic?
The problem you are having is the unit is going into protect.
You can try disconnecting all the speakers and then see if it turns on. If it does turn on you may only have a bad speaker.
Then just turn the unit off and plug in one speaker at a time. If it still turns on, that speaker is good. Keep doing this with each speaker until it goes into protect again, and then you know the last speaker plugged in is the bad one. Make sure you turn it off after checking each speaker.
If it still goes into protect with all speakers disconnected you most likely have a problem in the amplifier circuit.
I have the complete service manual in PDF format with parts list and schematics, but it cost $10.00
Let me know if you want to purchase it and I will give you instructions for that. I can give you a direct download link after purchase using PayPal.
If you would like any further help just let me know.
Jun 27, 2008 | Audio Players & Recorders
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Bad speaker/ access panel removal
As far as I know the speakers have to be removed from the back. Its a poorly designed cabinet.
Feb 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Speaker wire connector
Yes you can try Bogue Engineering at they carry awesome connectors and for your system you need the 4,2mm size. They only cost $21 for a set of 6 and they are much better than Samsungs parts. Hope that helps.
Jan 05, 2008 | Samsung HT-HDP40 System
Speakers hissing/humming
Hi Nate41
you won't do anithyng
may be is a bad resistor inside, that get hot and probably start to do this problem. try disconecting the speakers, and move to other place, more cooler, and try to see if you don't get the hissing and humming sound now. sometimes dust and hot places get to this problem.
beside that, may be a path to a problem.
Nov 26, 2007 | JBL CREATURE II Computer Speakers
Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio Logo
71 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
