My Zoom H2 microphone has suddenly stopped working. It won't turn on, it happened when I attempted to plug the power supply (with batteries as well) I was using an Australian socket outlet converter so it would fit into the power point. Please help?
  • 1 more comment
  • lwd4 Apr 28, 2008
    Sure, it's a Zoom H2 Handy Recorder (Serial No. 00123258) http://www.samsontech.com/products/produ... there is a link to what it looks like and details. Thanks!
  • lwd4 Apr 28, 2008
    Thanks for your help, have done as you said, just playing the waiting game! What is Flea power?
  • lwd4 Apr 28, 2008
    I tried everything and it still seems to not work. Although when I held the unit in my hand taking the batteries out in the first place it was warm, then 30 mins later putting the batteries back in it's still quite warm. Should I leave it perhaps a bit longer?
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 28, 2008
  • Maanita Chadha
    Maanita Chadha Apr 28, 2008
    Please reset the unit by taking the batteries and power cord out and disconnected for a couple of minuites this will drain the static power from the unit leave it turned off for half hour then reconnect a good battery set and you can try connecting the pwr too.
    this should help if there is no physical damage to the Zoom H2 microphone
  • Maanita Chadha
    Flea power will definately bring the unit working.
I recharged my camera using 5 volts nokia charger to my camera which has 3.5 volts battery only then what happened is whenever my camera on it will suddenly off while the lens/zoom is extended.. pls help.
The camera requires power to extend or retract the lens. The indicator of a low battery is your only notification that a loss of power will stop all functions of the camera. The camera should only be charged or operated with the manufacturers recommended power supply. The increased voltage as well as incorrect Amperage may have adverse reactions, such as you are now experiencing.
Dec 16, 2012 | Cameras
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
My Zoom H2 recorder is not recognized by my new computer with Windows 7. What can I do to solve this?
No solution, just a workaround. I have used the H2 with firmware 1.90 successfully with Windows 7, but lately the H2 is not recognized anymore. Built-in obsolescence maybe?
Anyway, I just take out the card and put it in a card reader. It is faster also. Card readers are cheap.
Sep 07, 2011 | Zoom H2 Digital Voice Recorder
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Will not power on from ac or batteries
I happen to know that for this certain camera it uses a battery which if it runs low enough on EN it will actually burn through the S.disc of the E!Reader in the batteries supplementary storage facility. In simple terms, a new battery is required, unless of course you want to spend $600 repairing the battery through an expert which now-a-days is almost impossible to find.
Oct 11, 2009 | Sony Cyber-shot DSC-H2 Digital Camera ...
My sony dsc-h2 turns iff immediately i turned it on
i think your battery is weak or you may be using low ampear battery, please replace it with energizer this may solve, in some cases the zoom motor and the related gears will make problem
if it struck you should open it then clean the dust with small air blower then fix it again
thanx
gulshan clt
Sep 03, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Toshiba Tecra M2 Series
Was the laptop on when it turned off? It may be a PSU problem but we can determine this by removing the battery. Make sure you disconnect the AC adapter while your removing the battery. Inspect the contacts and make sure`there are no black marks or any other dirt. Leave the battery out and plug in your AC adapter. Try the power again.
There are a couple of possibilities in terms of problems that I can suspect so far. Did anything out of the ordinary happen when the computer just stopped working all of the sudden.
1. Battery has failed and short circuited the contacts 2. Power supply failure 3. Motherboard could have failed in style. 4. Power contacts for the AC adapter are damaged.
Jun 15, 2008 | Toshiba Tecra M2-S730 Notebook
595 people viewed this question
 Grubhead
Grubhead
