Question about Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
Corba li 6000 speaker?
Does anyone know where I can get a new speaker for a corba li 6000? We have a bad one in one radio...
  • beddog Apr 28, 2008
    I meant cobra.... sorry
    Sergeant:
  • 250 Answers
Hello beddog,
I would recommend contacting the manufacturer directly for parts. You can find their contact information through their website at: http://www.cobraelectronics.com.
Best Regards
Ken
Go Ahead. Use Us.
Posted on May 01, 2008
One of the radios is stuck in the RX mode and does not receive. Factory reset an option? How
These radios do not have a factory reset capability. Here is a link to the manual: http://www.manualslib.com/manual/29317/Cobra-Li-6000wxc.html
Mar 08, 2015 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Everthing on the radios work but there is no sound from the speaker.The RX shows on the display and the the vibrate work when called. Whats up?
#1 bad speaker, #2 external speaker jack bad/shorted, #3 volume control bad/open, #4 squelch control bad, & #5 is it both radios no audio?
May 13, 2010 | Cobra microTALK LI 7200-2 WX VP Two Way...
I have a corba 148 gtl when you key it moves no audio
Sounds Like you have Bad wiring in your Mic connection. Also if you are using it at home on a power supply make sure its regulated so to not get the Humming sound. Also what type of Coax Cable and antenna are you using? Also are you using it at home or in the Car? Have you tried a different Microphone? Hope this Helps. Let me Know.........
Jul 04, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Regards
Raj
Jan 12, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
A bad speaker
Hello beddog,
Best Regards
Ken
Go Ahead. Use Us.
Apr 28, 2008 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Corba MicroTalk buttons not responding
This is an unfortunate situation. this normally happens when the radio CPU is damaged by water or some other factor. If this was a more expensive radio I would tell you to send it in to the factory but this type of radio is a low teer radio. Basicly a throw away.
Mar 02, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
This radios has a Reference Xtal, dropping the radio, could cause that the xtal goes out of frequency, this means tha the radios has a frequency error and the range of opearatin seems to be reduced or even null. With out knowlegement and equipmente, there is nothing that you can do.
Nov 21, 2006 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio Logo
75 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
