I purchased a Model 537 RCA antenna and it does not plug into my Converter Box (DTA800), nor does it serve to strengthen my TV signal. What is the model# of the "Smart Antenna" and where can it be purchased?
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
THE MODEL FOR YOUR TV
Posted on Apr 28, 2008
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
I recently bought a converter box DTA800 to go with my sony tv Triniton mod.KV-20FV300. It doesn't seem to work; programing, set-up. Please advise.
Ah, the problem is likely your antenna. Make sure everything is properly hooked up, and that your TV is on and turned to either channel 3 or 4 (whichever the unit requires, or you can try both and see which works) then turn the converter on, and check the manual that came with it for a way to check for your antenna's signal strength.
If your signal is good, then use the menu button on the remote and look for an "autoscan" feature, or "autoprogramming", something along those lines, and let the unit look for channels for you (mine requires this before you can use it, not that it matters because my antenna signal is weak). From there you can access the channels manually.
Hope this helps.
Jun 26, 2008 | RCA Televison & Video
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Connecting to an RCA DTA800 digital converter?
I got the new RCA converter box I followed the on screen info but i'm not getting a signal from my antenna so it doesn't show any channels
Mar 10, 2008 | Symphonic SC3913 13 in. Combo
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
