Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic pt-53tw53 convergence
In i had a convergence problem with my panny. i changed both ics. stk 392-110 to stk 392 180. when i was finishe i connected my dvd player, went to the convergence menu and lined everything up. the picture was beautiful. i left the movie playing for about half an hour to make sure everything was ok. i then put in the rest of screws closed up the back and connected the rest of my media. when i powered the tv back on i got three red flashes. is this because of i have an open resistor, maybe a bad solder or could it be related to the fact that i chang from stk392-110 to syk 392-180.
  • SIRSHIRLS Apr 28, 2008
    added more solder and wallah! thanks jaime
Any way you can show me what board the STK chips are on and how to get that board out of the TV to work on it
Posted on Jan 09, 2012
  • 2,326 Answers
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Posted on Apr 28, 2008
Warped picture
Tv have a problems known as a convergence problems,it dead.The tv convergence board require to change 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
No power
yes the 3 blink error means the convergence circuits have failed they are STK392-110 ICs
Mar 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Seeing triple red,blue,green
you have proble with the convergences ICs if the tree colors are at fault then also check your power supply voltages the polarization resistors
Feb 08, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53 53 in with bad picture
Sounds like you need new convergences ICs. There are two of them in your set sometimes you can get away with just replaceing one of them but I wouldn't recommend it. They are not too expensive are 15.00 each once you replace them you have to get into the service mode and adjust the convergence.
Sep 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53 tnp2a1h046 schematics
Cheap IC's = open resistor
Replace with X 480293 Kit Use IC's from kit to save $$.......T.
Mar 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53 53 Convergence?
power supply ,not enough b+ for proper scaning /deflection
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
