Question about Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner
No spin up
I HAVE BOTH DVD ROM AND DVD REWRITER CONNECTED TO THE COMPUTER. AS DESCRIBED IF A DISC IS PLACED IN THE DVD REWRITTER THE GREEN LIGHT FLASHES BUT THE DRIVE DOES NOT SPIN UP.THE DVD ROM OPERATES PERFECTLY IN THE MASTER AND SLAVE POSITIONS. THINKING THAT THE REWRITTER WAS FAULTY IREPLACED IT ONLY TO FIND THE SAME PROBLEM.I THEN FITTED TWO REWRITTERS IN THE COMPUTER AND THE SAME FAULT WAS ON BOTH.I HAVE ALSO TRIED A NEW IDE CABLE WITHOUT SUCCESS.
BOTH DRIVES ARE RECOGNISED IN THE DEVICE MANAGER.
REGISTRY ENTRIES FOR UPPER AND LOWER FILTERS HAVE ALSO BEEN DELETED AGAIN WITH NO SUCCESS.
I THINK THAT THE PROBLEM LIES WITH THE OPERATING SYSTEM WHICH IS WINDOWS XP MEDIA CENTRE.
ANY HELP ON THIS ISSUE WILL BE WELCOME
  • tlangloisjr Mar 10, 2009
    i have the same operating system and the same problem. You might be right it may be an windows xp media center creating the problem..
    Do you have any way of fixing this problem
  • 59 Answers
Did you adjust the jumper settings for corresponding master or slave position?
Posted on Aug 24, 2008
CD/DVD rom in laptop not working
The drive could be defective.
Dec 28, 2013 | Computers & Internet
Greeting I just bought "LG
Greetings... I think your having a problem with your hardware DVD R/W.
based on your observation...
1) The dvd rom drive is detected on your windows xp and by pushing open/close button still working... " this indicate that the power and SATA / IDE cable was properly connected.
2) And you've said "NOT SPINNING".... "means you have undergo testing by touching or listening DVDrom drive while the disk was inside after closing the disk tray which is right"
Therefore your DVDrom drive was defective... you can also check by opening the metal cover to see if the disk was spinning and if the laser of optical lens released a red light.
Jul 12, 2011 | LG GSA-2166D DVD RW Dual Layer Burner
How do i change dvd rom unit?
  1. Locate where your CD or DVD ROM drive connects to the motherboard and make a note of this. Make sure you know exactly how the gray cable was connected.
  2. Have the new DVD ROM drive handy and unplug and/or slide out (depending on setup) the old one. Unplug the cables from the appropriate places. You do not have to unplug the one going to the DVD ROM. Wiggle back and forth gently and then pull out.
  3. Attach your new cables and reattach to motherboard and power supply where you removed the old ones.
  4. Reattach the power cord and cables, but do not close up the computer entirely yet.
  5. Test your new DVD player by placing a disc in the drive and ensuring the green light comes on and you hear it power on. If this happens without a problem, then close up the case. If not, then check to make sure cables are securely fastened in the correct motherboard slots and to the power supply
May 18, 2010 | Computers & Internet
Unable to burn movie to DVD/CD
You can't burn a DVD movie using a COMBO drive or Compact disc rewriter, change your movie format from DVD to VCD and then try again, I recommend you use nero to make/edit movie and ImgBurn to make ISO image and burn it onto disc.
Dec 31, 2009 | Serif MoviePlus X3 Digital for PC...
External DVD rewriter with trapped disk
Straighten a paper clip and insert it into a tiny hole in the face if the disc tray. Push the paper clip gently in the hole and the tray will pop out slightly. Then grab the tray and pull it out until you can remove the DVD disc.
Oct 12, 2009 | LG SecurDisc 20x External Double-Layer DVD...
LG GH22LS40 will not work
You will need to check few things to get it working.
1) See that you have attached your DVD cable on the proper port of your motherboard.
2) See that the required jumper is fixed in proper place of your DVD writer.
3) Power cable of your DVD writer.
All the Best
Sep 11, 2009 | LG Electronics 16x DVD and 48x CD-ROM...
LG External Super Multi DVD Rewriter has frozen
there's a mini hole in front just put the needle or something like that and
push presto it will open try it!!!!!!!!!!!!!!!
Apr 27, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
LG Super Multi will not detect DVDs in the drive
Try the unit on another pc if it can read a dvd disc. If it can read a dvd disc then maybe you can try to uninstall the program for the dvd rewriter and then reinstall it again.
Mar 21, 2009 | LG GSA-E40L Burner
Pioneer DVR-111D doesn't read CDs/DVDs, discs don't even spin
I've deviced DVD-RW drive but not display with my computer. tell m..
Apr 21, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Open Questions:
Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Logo
150 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
