I have replaced the drum and it worked for a few days and came back to the same error. I have 2 of the same printer and it has happened on both.
SOURCE: Error message 004-321?
i don't see anyone suggesting solutions, jus the same problems over and over
I HAD the same problem...a couple of posts up/down, someone suggest to re-align the film roll on the Drum. This worked for me. There are two wheels on the outer-side of the film reel (the film reel is one of two reels on the main top drum). Take out the drum, not the green reel, but the other one. Check both ends and you can se/feel two little silver metal wheels (again, at the ends). Roll the film around with your fingers until it is aligned evenly with the wheels. The metal on the wheels should not be showing at all, they should both be covered by the film reel. Replace the drum and cross your fingers. This worked for me...I'm sure a NEW drum would fix the problem, as well.
SOURCE: dell 1700 laser printer
Call Dell. the 1700 has special reset instructions for resetting the drum count.
SOURCE: error message 004-321
Take the top off of the printer right above the toner cartridge and it worked again.
Hope it helps
I have the same problem.
Ich habe das schwarze Transportband von Tonerstaub gesaeubert und ebenfalls die Entwicklertrommel. Ausserdem alle Tonerpatronen entfernt und wieder eingesetzt. Der Fehler bleibt.
Got error 004-321 asking to re-start printer
same problem... I reseated the drum .. still a problem
I have error message 004-321. I installed a new drum earlier in the day. It worked for a while then the error message showed asking for me to restart the printer. I have reseated the drum and turned the printer back on and I get the same message.
Same issue
I didn't change any drums, but this same error message has appeared spontaneously. And, of course it won't print anything.
same problem. any fix?
GsmComm.GsmCommunication.MessageServiceErrorException: Message service error 321
at GsmComm.GsmCommunication.GsmPhone.HandleCommError(String input)
at GsmComm.GsmCommunication.GsmPhone.GsmComm.GsmCommunication.ICommunication.ReceiveMultiple(String pattern)
at GsmComm.GsmCommunication.GsmPhone.GsmComm.GsmCommunication.ICommunication.ReceiveMultiple()
at GsmComm.GsmCommunication.GsmPhone.GsmComm.GsmCommunication.ICommunication.ExecAndReceiveMultiple(String command)
at GsmComm.GsmCommunication.GsmPhone.DeleteMessage(Int32 index)
at GsmComm.GsmCommunication.GsmCommMain.DeleteMessage(Int32 index, String storage)
at SMSManager.frmmain.Sim_Read_First(CommConfig co)
