Panasonic tv fault
The tv {panasonic CRT) screen blancks out with a white line at the center and after awhile it opens up and then blancks out same way. so what is the problem
  • 71 Answers
Resolder vertical output ic pins
Posted on Apr 28, 2008
  • laryy56 Sep 19, 2010
    where inside the tv do i find these pins?
    what do they look like?
    how do i get to them?
    i'm fearless, when armed with knowledge.
********* vertical line in panasonic 55 tv model tc-p55ut50 already changed the center board now i have a big white line in same place
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 25, 2017 | Panasonic Televison & Video
PANASONIC TV MOD TCL58E60. VERTICAL PURPLE LINE ONLY DOWN CENTER OF SCREEN. IT IS INTERMITTENT, AND IT APPEARS IN FRONT OF THE MENU SCREEN. ANY SUGGESTIONS?
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 02, 2016 | Panasonic Televison & Video
Panasonic 65 in. Viera 3D TV has a 3 in. 'static bar' down the center of the screen. Can still see the picture but bar is noticeable, mostly in the center of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 29, 2015 | Panasonic Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
http://electro-medical.blogspot.com/
Apr 05, 2017 | Panasonic Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
10 fine white lines at top of tv screen
replace capacitor at vertical section
May 26, 2010 | Panasonic CT-27G14 27" TV
My panasonic tv started displaying white lines
some capacitors are faulty in the vertical section of ur tv,, they must be replaced ,calla service pro to replce it 100mfd 50v capacitor
Mar 18, 2010 | Televison & Video
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Aug 30, 2006 | Panasonic CT2722H TV
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
