Question about Brady ID PAL Thermal Label Printer
Does not print
Everytime I hit print it says printing but nothing prints.
I've changed the batteries and cartridge still no luck.
thanks
  • turners Jun 18, 2008
    Same thing here. Brand new batteries and it says it's printing, but nothing happens. I've tried everything but take it apart!
  • Anonymous Jun 28, 2008
    Same problem, cant find answers ANYWHERE!
1. Turn off the printer.
2. Turn it over and remove the battery cover.
3. Looking above the batteries, you will see a square opening into the upper part of the printer. In that opening you will see a white gear. Sometimes it seizes. Take a long, thin object (screw driver, letter opener, etc) and rotate the gear. It does not matter which way you turn it.
4. Because your range of motion is limited in the small opening, turn the gear in the same direction about 10-12 times so it gets a full revolution.
5. Now turn on your printer and try it again.
Posted on Jun 28, 2008
  • stolfa Jun 28, 2008
    Depending on your model, you may see the white gear under the cartridge. Same repair as stated above.
We ended up purchasing a #8 Torx driver to open up the unit. Found a piece if vinyl label stuck between two gears. Once that was removed it worked again.
Posted on Jan 28, 2009
Hi! I have a powermark printer...when printer is "online" it gives an error "unknown supply tape. Reload Tape". I reload the tape but when you click the print command the error " unknown supply tape. reload tape" pops-up again..
Any solution?
Posted on Sep 10, 2010
  • 3 Answers
I had the same problem. I opened up the unit and found that the small drive gear (right next to the one mentioned above) had lifted up on the shaft and was no longer engaging the other gear. I could have probably noticed this from the battery compartment. I pushed it back down and now the unit works fine.
Posted on May 26, 2010
  • ALbert L Owens Jr Sep 26, 2010
    ALO5151 I opened the case on the printer what i found was that the main small cog on the drive motor was slipping on the motor shart the motor was turning but the small gear was just sitting there spinning i used a small label from the wire marker label and cut off a piece of the label and wrapped it around the shaft to help tighten up the gear and it worked perfectly keep in mind that this is helpful but you reall should order a new gear i'm usind this temporary because i need to use the machine to print out some labels right away in the mean time i will be ordering a couple of new gears for the drive motor i will also order all new gears for the complete running gear it will be easy for me to order since i live right here in milwaukee wisconsin where the labeler is manufactured
  • GeneJockey Oct 10, 2010
    I would like to order the same small white gear for my Brady LabPal any information on where I can order this part would be appreciated, (like phone number and part number). Thanks
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
I've got a HP C4780 printer which I have had for around a year but only used about 5 or 6 times! Despite the ink cartridges having ink in them, the black cartridge is not printing at all. Not even a...
The ink solidifies right behind the micro printing nozzles. The only way to attempt to rectify this is to dip the print face into some warm (not hot) water for a minute or two, and dry after wards. If the cartridge recovers, Yippee, if it doesn't, replace.
Common problem. Be thankful it isn't a Canon or Epson, which entails replacing a seriously expensive 'print head'.
Jun 08, 2011 | HP PS C4780 All in One InkJet Printer
My canon pixma ip3000 will not print in black in. It was print fine and one day the black ink came out less and less on the paper when I print. I change a new black cartridge and it still does not help and...
Print head is fubar and for the cost that Canon will hit you with for a new print head you really have no alternative - new printer is cheaper than print head and also comes with a warranty.
Aug 06, 2017 | Canon PIXMA iP3000 InkJet Photo Printer
New black ink cartridge installed.printer is not printing properely since then.cleaning option from solution center performed.No change.print cartridges making hitting and rubbing sounds from inside the...
It appears that it has carriage stall problem. Please speak to tech support, so that if it is a hardware issue, and if the printer is in wty, then it could be replaced .
Aug 14, 2010 | HP PSC 1410 All-In-One InkJet Printer
Printer appears to be printing but nothing prints on paper
if your printing off a pc you need to hit print to activate
May 01, 2010 | Canon PIXMA iP90 Mobile Printer
I need your help my printer quit printing, I was low on ink and it quit printing after I printed a page. I changed cartridges and it still would not print, so I swapped cartridges with a different printer...
So it prints the self test (test page) or not?
If nothing is printing from at all (printer moves likes it is printing when in operation, but no ink hitting paper) there may be a blockage on the jets or the information is not getting to the printer properly if these same cartridges work on another printer.
I would lift lid and carefully check each one and wipe with a thin cloth the remove any clotted ink and dirt.
You have already reinstalled the drivers, but I would get the latest ones you can from www.hp.com
Finally I would cold reset the printer - usually holding the go button pressed in while hitting the power button on and off - will reset rthe calibration and give you a better chance of fixing.
Also if you have the cartridges for the wrong model, they may physically fit in, but the chip on the cart will tell the printer theres a problem and won;t print.
Summary:
- Check cartridges - off the top of my head (please check!) you should be using HP 45 for Black and HP 68 for Colour (if using a different brand, fine but the numbers are thee same)
- Download latest drivers
- Cold reset printer and install again
Good Luck
Mar 14, 2009 | HP DeskJet 940c InkJet Printer
Print cartridge error
Press either the menu or setup button.
There should be a maintenance section where you can do eletronic print cartridge cleaning and print head alignments and calabrations.
Some of them can be done at the computer if you access the driver properties.
You can clich the print queue and look around there also for print head cleaning and some other diagnostic procedures.
If those don't resolve the problem, remove the cartridge and take a fuzzless cloth dampened very slightly with alcohol and clean the contacts to the print cartridge.
PLEASE REMOVE THE POWER when cleaning though.
Dec 20, 2007 | HP PSC 1315 All-In-One InkJet Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Brady ID PAL Thermal Label Printer Logo
949 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
