Question about Panasonic Panafax DX-800 Plain Paper Laser Fax
Cannot get unit to answer.
Unit was working perfectly and all of a sudden it stoped.
    Scholar:
  • 130 Answers
Be more specific
Posted on Jun 12, 2008
  • Alvin Barnabas
    Alvin Barnabas Jun 12, 2008
    It May have inadvertantly been set to manual recieve
  • Alvin Barnabas
    Alvin Barnabas Jun 16, 2008
    Make sure machine is on Auto Recieve
Kkitchenaid side by side refrigerator. The ice maker stoped working, but the in door water despensor works perfectly
TRY PULLING OUT THE "ICE AUGER" AND RESETTING THE ICE MAKING UNIT ITSELF,MOTOR SHOULD RESTART AND FREEZE...UNLESS YOU RARELY USE IT,IN THAT CASE YOU MAY HAVE MOTOR ISSUE?? STAY IN TOUCH,LET ME KNOW
Jun 06, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Philips hts6600 remote stoped functioning
Did you get any answer as i faced same problem... and it's hard to find out how to fiw or even replace it
Sep 20, 2012 | Philips HTS 6600/12 Home Theatre...
1996 buick park ave ultra- air conditioner turns on but now air flows through the vents it was working fine! and all of a sudden it stoped
I answered this in a different question but I was assuming the air was not coming out of the right vent.
If the air is not blowing at all, you need to check for voltage at the blower fuse, the blower motor, and the resistor.
If there were a blockage such as a dirty cabin air filter, you should hear the blower running.
Jul 17, 2012 | Cars & Trucks
1997 toyata tacoma AC suddenly stoped working
Not sure where the realy is, but there should be a 30 amp fuse in your fuse box. Did you check that?
May 25, 2009 | 1987 Toyota Supra
Scanner quit working on Dell AIO962
Apni ma mt chuudvao mujh se philips walo
Apr 29, 2009 | Dell 924 All-in-One InkJet Printer
Climate control bmw e36
http://www.macadamizer.com/bmwfix.html
Feb 10, 2009 | 1997 BMW 328
Epson Stylus C46 InkJet
Check USB cable.
Try different cable and connect it to different usb port.
If it is not the cable, do the following driver reinstall:
Disconnect printer from usb
Remove printer from 'installed printers' in Windows.
Install again driver from disk with printer not connected.
connect printer when required by setup procedure or after installing drivers.
If it still does not wark then the printer is faulty.
Jul 11, 2008 | Epson Stylus C46 InkJet Printer
Haier XQG50-11 spin and dryer do not work
Same thing happened to my unit. It turned out to be the no spin switch which I never used anyway.
The switch had gone bad even though it was never used it. It was broken in the no spin state. The connectors on mine were a bit chared looking.
Take the top cover off the unit and remove the two wires from the no spin switch. Place a jumper between these two wires bypassing the switch or replace the switch.
In the no spin cycle the unit will not spin or dry.
I bypassed my switch and the unit runs perfect again.
Mar 15, 2008 | Washing Machines
Ethernet card suddenly stoped working properly
If you can send packets but not receive, then the hardware is ok, it is a setting on the card that is incorrect or the Windows connection repair has changed the card address. If your router is set at Automatic DHCP then it should give your card the correct IP address and also DNS. In sending your card is trying to communicate with the router but not receiving an answer.
Dec 21, 2006 | Toshiba Satellite A105-S4004 Notebook
Panasonic Panafax DX-800 Plain Paper Laser Fax Logo
32 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
