When I put in a new inkjet, I get a sheet telling me to follow the steps using this sheet. The next thing that pops up is "Open the hp toolbox and calibrate". Where is the toolbox and what does calibrate mean?
  • lantfn Apr 28, 2008
    This worked for me. Thank you so much for helping me with myt question. YOU DID GOOD!!!
    Lois Newman
What your printer manufacturer calls calibrate is a test that draws
small black lines on a piece of paper, in 5 different instances. You pick the number that looks the straightest. But i installed a 50$ HP deskjet this week that i didn't calibrate and it prints just perfect.
_Your Q where is the toolbox is the printer software that is on your computer that is used tell how much ink level is in the cartridges etc. print test pages...on XP click START.....click Control Panel......
click PRINTERS........open the printer properties for the installed
printer then just start looking around
Posted on Apr 28, 2008
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
Only the black ink cant print
Hi mary vie Capistrano,
Is this a new HP OEM or Reconditioned cartridge?
Have you tried a new cartridge?
Clean the print head:If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Apr 14, 2012 | HP Photosmart C6180 All-In-One InkJet...
Install new inkjet ?
Hi ,
This can be downloaded from the hp website so open up the hp website by typing just www.hp.com/support
you will get hp technical page select united states from the list and then click the go arrow then support and drivers page will open up .Under step one check the radio button that says download drivers and software and in step 2 put the name of the product HP PhotoSmart 7960 InkJet Printer click on Software and driver downloads go ?then select the operating system ?click next?click on the + sign next to driver(3)?click on download on the one that says software and driver?click on save?browse it and save iton the desktop ?run it and follow the instilaltion steps .
all the best
May 19, 2010 | HP PhotoSmart 7960 InkJet Printer
I have a HP Deskjet 882C printer and for the past month we are having problems printing text (B&W). We have removed the black ink cartridge and it still has a lot of ink in the cartridge. When we put a...
To clean the HP Inkjet print cartridges from the HP Toolbox, using a Windows operating system, perform these steps:
  1. Double-click the HP Toolbox icon on the computer screen.
  2. Click the Printer Services tab.
  3. Click Clean the print cartridges and follow the directions on the screen.
If the print quality improves after completing this sequence once, but the quality is still not quite good enough, repeat procedure. Start at Step 1, or click the Clean Again button on the final cleaning window. If this process does not improve the print quality, the HP Inkjet print cartridges might be low on ink. See the document that is provided with the black HP Inkjet print cartridge for instructions about how to use the ink level sensor to determine if the cartridge is low on ink. Replace the HP Inkjet print cartridges, if appropriate.
Jun 25, 2009 | HP DeskJet 882c InkJet Printer
Printer tells me to install new color cart. after i have put in new hp cart.
1. Press the Setup button.
  1. Use the arrow keys to select Tools and then press the OK button.
  2. Select Clean Print Cartridge and then press OK . The device prints a test page.
  3. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  4. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
  5. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
  6. Remove and re-insert, while the product is switched on.
If still bad, swap out the cartridge.
Hope this helps
Regards
Apr 19, 2009 | HP Officejet 7310 All-In-One Printer
Cartridge alignment using vista
Option 1:- This method of aligning or cleaning ink cartridges will work for most computers and printers. Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the following steps are not the same as those you see on your computer, skip to the next option. Each option does not work on every computer.)
Click Start, then Printers and Faxes.
Click the desired printer icon to highlight it.
Click File, then Printing Preferences.
Click the Services tab.
Click Open Toolbox.
Click the desired task.
Option 2:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer)
Click File and Properties.
Option 3:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
Double-click the XXXX Printer Assistant icon on the Desktop.
Click the Utilities button or the Tools and Updates button.
Click the Printer Maintenance button.
Option 4:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Right-click the Printer icon on the Taskbar.
Click Open Toolbox.
On the Device Services tab, click the desired task.
Option 5:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Click Start, Programs, HP DeskJet (your printer) series vX.X, then HP DeskJet (your printer) series vX.X Toolbox.
Click the Device Services tab.
Option 6:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, go to one of the other options. Each option does not work on every computer)
Click Start, Programs, Hewlett-Packard, HP DeskJet XXXX series, then Printer Assistant.
Option 7:-Double-click the HP Director icon on the Desktop.
Click the Utilities option.
Jul 17, 2008 | HP DeskJet 5150 InkJet Printer
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
    3. Click Settings .
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Jan 09, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
    3. Click Settings .
Please let me know if these steps helped you or not. Thanks
Jan 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP PSC all-in-one printer skipping lines
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK . The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  5. Open the Printer Toolbox . There are two ways to do this:
  6. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage.
  1. Gather the following items to clean the cartridge and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridges on during cleaning.
  2. Open the product cover and wait until the print carriage stops moving.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product.
  5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the print-cartridge contacts. Do not touch the nozzles. Figure 1: Cartridge electrical contacts c00832021.gif
  7. Clean the contacts in the print carriage, inside the product. Figure 2: Carriage contacts c00246272.gif
  8. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge, plug the product back in, and close the product cover.
  10. Try to print again. If the issue still appears, continue to the next step.
In the black print cartridge, this problem might be caused by sediments collecting in the nozzle area. Perform the following steps to solve this problem:
  1. Remove the black print cartridge.
  2. If the carriage has a latch, re-latch it and then close the printer. NOTE: If the printer is not closed, it cannot adequately protect the remaining tri-color cartridge.
  3. Place the cartridge on a level surface with the nozzles up (label down). Figure 4: Cartridge with the nozzles up c00260331.gif
  4. Allow the cartridge to sit undisturbed for two hours.
  5. Reinstall the cartridge and print another diagnostic page.
    1. Load letter or A4 unused plain white paper into the input tray.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Make sure that the test patterns show a complete grid and the thick color lines are complete.
    • More than a few broken lines in a pattern can indicate a problem with the nozzles. You might need to clean the print cartridges.
    • If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black print cartridge in the right slot.
    • If any of the color lines are missing, or if the pattern appears faded, streaked, or shows lines, this might indicate a problem with the tri-color print cartridge in the left slot.
  6. Look for defects on the page. If the diagnostic page shows no defects for the black cartridge, and if the cartridge was new, align the cartridge. To align the cartridge, follow the steps:
    1. Load letter, A4, or legal unused plain white paper into the input tray.
    2. In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Toolbox . NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device . The Printer Toolbox appears.
    3. Click the Device Services tab.
    4. Click Align the Print Cartridges and a print cartridge alignment sheet is printed.
    5. Load the print cartridge alignment sheet with the print side down on the right front corner of the glass.
    6. Press the Start Scan/Reprints button and the HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet. For aligning the cartridges from the hardware only, follow the steps:
    7. Load letter or A4 unused plain white paper into the input tray.
    8. Press and hold the Cancel button and then the On/Power button.
    9. While the Check Paper and Check Print Cartridge lights are blinking, press the following buttons one at a time in the following order: Cancel , Number of Copies , Paper Type , Color Start
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
101 people viewed this question
jasbo
jasbo
