Clothes dryer motor overheating
I have replaced the motor in my kenmore clothes dryer and the new one is still overheating, even when the dryer is on air fluff
Have you repalced the thermostat?
Posted on Jan 12, 2009
My Kenmore Elite Oasis Model 6703 is overheating even when I disconnect from the venting system in the wall!
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 10, 2011 | Kenmore 67032 Dryer
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
Overheating dryer - motor replacement???
Good day,
You said "The dryer is still overheatng". If your not describing the motor but the whole machine then that problem will have to be resolved.
Maytag's build lint up badly in the blower housing area and the duct between it and the filter. Requires disassembling the front of the dryer and cleaning that area as well as determining if the blower wheel is loose on the motor shaft requiring replacing.
If the overheating is the motor itself, then replacing it would be a common item on that brand.
May 14, 2010 | Maytag Dryers
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore 66712 dryer stops in cycle
Your motor bearings are worn out and overheating the motor. It has a overload protector that shuts it down when it overheats. Solution is to replace motor or new dryer. Hope this helps!
May 19, 2009 | Kenmore Dryers
Kenmore electric dryer is overheating
Sounds like you need to replace the temp sensor.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
My Kenmore 90 Series Dryer keeps overheating. I've cleaned out all lint I can find in the traps, the exhaust vent leading out, and even popped the bottom panel off cleaning that area out. Is the motor...
By overheating I presume you mean the high temperature fuse is tripping.
The two most common causes are poor air flow and a bad themostat. If there's a good flow of air coming out of the exhaust vent then it's likely the thermostat. Expect to pay $20-30 plus labor for a new one.
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
May 08, 2008 | Dryers
Washing Machines Logo
387 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
