Question about Bose 901 VI Main / Stereo Speaker
Bose series II active equalizer
How do you connect this equalizer? Does it go between the power amp and the speakers?
  • scottandpeg May 16, 2008
    I paid $30 for a set of bose speakers sight unseen from someone at church. I got the 901s with equalizer. They came with wires the size of car jumper cables. What do I do with them?
    Problem Solver:
  • 18 Answers
It can be connected 2 ways. go through the manual from the link below
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Posted on May 22, 2008
Yes, it goes where you said.
Posted on May 18, 2008
How to hook up bose 901 active equalizer to onkyo grand integra pre amp?
You don't.
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
Sep 01, 2014 | Audio Players & Recorders
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 and Tube amp
Yes! When the Bose ~Steve901 first came out that was the amplifier of choice -like the McIntosh classic amps. The 901s have their own equalizer as that speaker system is a phased-array,
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
How to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Sep 09, 2008 | Bose 901 VI Main / Stereo Speaker
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
Oct 30, 2007 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
360 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
