Phaser 860 maintenance tray A stuck - Office Equipment & Supplies
  • 2,072 Answers
1. The Maintenance Drawer will not come out. - Often times this can be overcome by waiting 2 minutes for the ?Hot Ink? timer to expire, then remove the Maintenance Drawer. 2. If the printers Maintenance Drawer is locked in place and can not be removed and there are no cleaning functions currently taking place then the Maintenance Drawer can be unlocked by removing the right side cover and move the Cap/Wipe/Purge belts evenly down to the home position. This will raise the sensor flag from I/O Left and disengage the locking pin that is preventing the Maintenance Drawer from being removed. 3. If either Maintenance Drawer Guides (Blue Plastic Rail guides) have been replaced or removed and reinstalled and this is preventing the proper insertion of the Maintenance Drawer then check on the outside of the chassis frame that both rear locking tabs for the rail guides are protruding through the printers frame and are properly seated and notched into place. ? If they are not properly installed and seated then remove the rail guides and reinstall and then test for proper insertion and removal of the printers Maintenance Drawer. 4. Obstructions or spilled ink (wax) may be covering the Drum Maintenance rail guides and preventing the proper insertion or removal of the Maintenance Drawer. ? Check the printers Drum Maintenance Rail guides for any paper scraps or spilled ink or leaking ink from the Printhead. Make sure that there is no spilled ink under the Maintenance drawer waste tray and that it is seated properly. TROUBLESHOOTING TIPS AND HINTS: In order to provide more clearance when removing the printers Drum Maintenance rail guides, use the X-axis gear to move the Printhead away from the drawer guide that you are removing/installing. Also raise the Cap/Wipe/Purge assembly to reduce interference. When a drawer rail guide is mounted, double check its rear locking tabs where they go through the chassis side frame. Both blue tabs should be visible on the outside of the frame of the printer.
Posted on Apr 28, 2008
How do I replace a Transfix Assembly
There should be a door on the right side of the printer. Replace the maintenance kit and clean the waste ink tray.
Apr 14, 2012 | Xerox Phaser® 860, 8200 Standard Capacity...
I have a phaser 860 and it has a paper jam issue. There is no paper jam. I am wondering if the maintenance roller can cause this? It has been sitting around for well over a year and I just started using it...
Most likely if it is not moving the paper out of the tray the rollers will need replaced. You can try cleaning them a few times with soapy cleaner, and alcohol.
Honestly, you could probably pick an entire 860 up on E-bay for cheap for some of the parts, But feed rollers I would get new.
Not sure of a non Xerox source for those. You can try Precision rollers, The Parts Drop, and Xerox phone number to order those parts would be 1-800-835-6100, follow prompts to parts and you can just inquire. They will give you prices and look up what you need with no commitment.
Jan 19, 2010 | Xerox Tektronix Phaser 850N Laser Printer
Why is this tekronix 860 printer kept flashing error message saying missing upper tray. However, all trays are intact. It looks like a sensor issue
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
May 18, 2009 | Tektronix Phaser 860 Thermal Printer
Phaser 860 error"replace paper tray "
Missing plug in tray on right side of tray. Top hole. Replacement plug can be gotten from xerox parts or inktechnologies.
Apr 03, 2009 | Xerox Phaser 7700 Laser Printer
860 09.007.42:57383 What do I do? phaser 860
You could try the colour test procedure and just melt it out but that will waste a lot of link in all of the sections
Mar 08, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 860 ink scratches off sooooooo easily
An 860 has no fuser. That sounds more like either a maintenance kit or transfix roller needs replaced.
Jul 11, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8200
Normally its the maintenance tray clutch slipping.
Or the maintenance tray ends are worn.
You can remove the left cover and clean the clutch, its on the lower part of the frame, and take your kit out and there are 2 tabs sticking out the ends that were on the last 1/4th inch.
The Printer's Front Panel Displays Printer Error - Report Fault: 07,005.47
The Drum Maintenance home sensor actuated, but not at the expected time. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts): The wiring harness from the clutch is not seated properly on the I/O Left board. Check all wiring connections to the I/O boards and verify. connectivity. TROUBLESHOOTING TIPS AND HINTS: Inspect the maintenance drawer lift pins for wear. See Service Bulletin #445 Rev #1 Replace Drum Maintenance Cam Followers for Inadequate Drum oiling Due to Worn-out Lift Pins. Run diagnostics to verify clutch and sensor operation. Also verify that the drum maintenance shaft is properly assembled. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 401087100 1 CLUTCH; LARGE,DM,SAFETY CONTROLLED 436041400 1 MAINTENANCE DRAWER W/10K ROLLER & COUNTER/PHASER 860/8200 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
May 05, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
607 people viewed this question
