Question about Sharp AR 201 Copier
AR201 displays e7
Sharp AR201 is displaying E7. What does that mean?
  • Anonymous Oct 05, 2008
    I have the same problem. The machine prints OK at first, but then if there is a break in printing it makes a noise as if it's stuck and eventually the motor goes off and the display alternates between E and 7 and no other code.
    Scholar:
  • Sharp Expert
  • 120 Answers
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Posted on Jun 15, 2008
  • unkl foddy Feb 10, 2011
    When the error flashes up you need to hold down the Start button to read the subcode.
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
Sharp ar5516 error e7
with such error displayed press the print button, the machine shows another sub code, if it is 11 or 12 means a trouble with the scanner section.
to fix take out the glass ,clean the white strip left, the lamp reflector and mirrors, open the lens cover (5) screws, clean the lens and CCD.
if the subcode is 16 a trouble with laser
Nov 18, 2011 | Sharp Office Equipment & Supplies
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp MX-6201n get e7-06 error when scanning to thumb drive
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
Oct 08, 2010 | Sharp Office Equipment & Supplies
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
Sharp AR-151
E7-03 LSU problem (laser unit) E7-04 CCD white level problem E7-05 CCD black level problem E7-12 Shading problem
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
E7 sub 11
The problem is on the scanning unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
Aug 03, 2008 | Sharp Office Equipment & Supplies
Displays E7. Meaning? Fix?
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
Apr 28, 2008 | Sharp AR 201 Copier
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 201 Copier Logo
272 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
