LOOKING FOR INSTALL / MAINTENANCE MANUAL
I AM AN HVAC TEACHER. SOMEONE HAS BROUGHT US A DESA MOD. VP2000BTA FOR CLEAN-UP AND CHECK OUT. I WOULD LIKE MY STUDENTS TO BE REFERRING TO MFR'S INSTRUCTIONS. I WAS WONDERING IF YOU FOLKS COULD SEND AS A PDF OR ANY OTHER SUGGESTIONS
THANKS
Anyone know i am installing new base boards 1500 or 2000 240 volt how many wan i put on one circiut
Posted on Apr 28, 2008
I need replacement logs for a Desa Model CGFB32CA. No one lists the log numbers, including the manual. Where can I get the item number?
As you probably already know, DESA International is no longer in business. However, depending on the age of your unit, some parts are still available, as is the Owners Manual. The parts for Comfort Glow gas logs (which is what you have. And probably purchased them from Lowe's some years ago) are interchangeable with DESA's Vanguard line.
You can find what you're looking for at www.desatech.com. However, don't be shocked by the price of the replacement logs.
Feb 05, 2011 | Desa International Wall/Window Air...
THERMOCOUPLE BAD ON MY REDDY HEATER MOD#TB101 CANT FIND PART # FOR IT
The Part # for the Thermocouple is 104146-05.
Keep in mind, DESA International is no longer in business, but I think you can find it at
www.reddyrparts.com
Feb 01, 2011 | Desa International TB101 Heater
Grade of fuel required for DESA heater
Dave you can use all three types that you have listed.
The pump is typically set for Number 2/ Diesel Fuel and if you run Kerosene the unit will run a little bit hotter but with a 3E359B you will typically run diesel due to the amount it will use and the increased cost of kerosene over diesel fuel.
Number 1 is similar to kerosene and is the fraction that boils off right after gasoline.
Number 2 is the diesel fuel that trucks and some cars run on, leading to the name "road diesel". It is the same thing as heating oil.
Feb 10, 2010 | Desa International Heating & Cooling
Fireplace Mod # CGCFTP it will light but will turh off in a few seconds., ???
Take your pilot assembly out and clean. Once they get dirty, they tend to do just what you are describing. If this does not fix it, you may need a gas valve but I'm nearly positive that cleaning it will work. Good luck.
Oct 18, 2009 | Desa International GWP20T GLOWARM Wall...
I HAVE A APRILAIRE 550 HUMITIFIER. MY FATHER TOLD ME TO CLEAN IT WITH BLEACH. HOW DO I CLEAN IT? KATHY HUTCHASON
Hi Kathy,
The water panel fills with mineral deposits. For only $10 - $14 you should replace the water panel once a year.
When you remove the old one. Warm water, or bleach or white vinegar will clean out the inside very nice. Take model number with you to the hardware store or Lowe's or home depot. There are three sizes to pick from. Your model number will be on the box for the panel you need. IMPORTANT.....When you install it make sure that the black sprayed on dot on the edge of the panel is the end that goes up.
This is very easy to do, you will be fine. Just change it every year for maximum and economical performance.
Good Luck
HVAC Teacher
Mar 08, 2009 | Aprilaire 550 Humidifier
Hunter model 33201 stinks due to mineral build up, but I can't get the fan part disassembled to clean it. There are no more screws to take out, and I don't want to break it... help
Soak what you can in white vinegar. For the rest put some of the vinegar in a spray bottle and carefuly spray and use an old toothbrush.
Good luck
HVAC Teacher
Feb 17, 2009 | Hunter 33201 Humidifier
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Feb 10, 2009 | Aprilaire 700 Humidifier
Water runs only with temp dial held in test/reset position.
I assume the temp dial you are referring to is the humidistat. If it only works when you apply manual pressure. You have bad contactsin the humidistat. Replace the stat.
Good luck
HVAC Teacher
Feb 02, 2009 | Aprilaire 600 Humidifier
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
