I have a Goodman A/C unit, Inside unit P/N A42-15, my problem is inside blower won't turn on when in A/C outside unit turns on and the copper pipe going to inside unit gets cold, but no blower to circulate air, can some times get blower tot turn on by reseting inside units circuit breakers, also heater works fine.
  • 1 more comment
  • gonzales393 Apr 28, 2008
    whole unit has been in an power off status for over 2 hours when compressor was replaced and unit still malfunctioned
    Unit was installed end of 1999, 2 thermostats have been changed for other problems, compressor replaced last year.
    The repair was for the outside unit, no A/C at all, never reported inside problem since fan works manually,and I would leave it running all the time and let the outside unit kick on and off as needed, but now with the price of everything going up I am trying to cut all unneeded electrical use. I am currently trying to obtain a schematic or repair manual for unit, since I don't like to pay $90.00 an hour labor, Will figure this out. Thanks for the help.
    New Friend:
  • 3 Answers
Get it from here
CASTLE AC
Posted on Jun 30, 2016
    Master:
  • 788 Answers
What about the blower time delay relay: http://americanhvacparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=SEQ1370738&Category_Code=
This usually delays the blower until the air is cool, but if it's faulty it might not start the blower at all.
Posted on Apr 28, 2008
    President:
  • 2,712 Answers
It looks like the condenser motor is working, as the copper tube is cold. However, it looks like the shaft that connects the condenser motor to the propeller blade (blower) is not functioning properly, or there is some kind of obstruction that is preventing the propeller from rotating.
If you are not familiar with this kind of work, I would recommend that you get a qualified A/C technician to look into this, or if it is under warranty, then get the local Goodman Service Center to send out a tech.
Hope that helps...
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If, however it has not, then please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best as I can.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • 2,326 Answers
It sounds more like a loose contact if it works intermittently.
I would suggest to double check the wiring connections specially where they connect to a different board or panel.
  • Jaime Hernandez Apr 28, 2008
    Click here to get a repair manual, it might not be the same as your appliance but the basic functions are the same.
    Just make sure to unplug or turn the breakers OFF when working on this appliance.
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    Maanita Chadha Apr 28, 2008
    All you need to do is to turn the AC completely off and unplug the power cable from the wall outlet and leave it turned off for 2 hrs
    and then turn the unit and then reset the unit circuit breaker.
    This will be onto the normal operation.
    Hope this helps
  • Maanita Chadha
    Then you need to contact the technician as you have already spend money in getting the unit repaired you should consult that the work is still pending and he should take care of the issue.
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
Why is the inside fan is not running and hearing a gurgling sound with the outside unit still running?
The gurgling sound sounds like freon is flowing thru the system pipes. Is the larger of the 2 copper tubes running cold to the touch? Hi-Low module make also be the problem. It tells the inside fan when to turn off and on.
Sep 05, 2014 | Coleman Heating & Cooling
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
I have a Goodman A/C unit. When I turn on the therostat the outside fan does not turn though there is a mild buzz sound. The blower blows warm air inside of my house. What could the problem be?
Does the cpompressor come on if not the sound you here maybe the contactor. Check float switch inside. It is underneath the unit or in front of the air handler. Drain stopped up need to blow out drain. Check outside breakers. possible bad capacitor on unit. Need service tech. Rusty
Jun 13, 2009 | Goodman CKL42AR42 Air Conditioner
Inside blower not starting every time
You have a voltage bleed somewhere or a short, whatever you want to call it. Do you have a control board on this unit where the relays are integrated into it or do you have the old type where the relay is separate? Anyway, you need to take a meter and take voltage readings to the motor when it's acting up and when it's running right. I have had the same problem with a Goodman unit before and it turned out to be the tstat! What I would do is remove the cover off the tstat and take a small jumper wire and touch the r terminal to the y terminal. If the motor starts right up, you know it's the tstat. If you have the same problem, then the only thing it can be is a low voltage short to the unit from the tstat, bad control board if you have one, or a bad relay. But if the unit is working fine in heat, it's probably not the relay. I hope this helps.
Apr 08, 2009 | Goodman Heating & Cooling
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Ac problems
Hello from KOOLBREEZES, this is a simle problem and easy to fix. You have 2-lines going to / from your outside unit. a SMALL COPPER -line and a LARGE COPPER line with insulations. The fat line is suppose to have moisture on it wheres it,s not insulated which tells you you have enough refrigerant gas comming back to he compressor but if its dry you,re low on freon and need a charge or the outside condenser is dirty and not getting rid of enough heat!
Jun 02, 2008 | Heating & Cooling
Heating & Cooling Logo
349 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
