Question about Motorola Mobility W220 Cellular Phone
Internet Connection Sir, I need to ur help, i have One W270 Set. This set can't install the node. How to connect this device through data cable.Wt i Do please dot he need ful. Reg Jiyesh
  • Anonymous Aug 26, 2008
    usb cabe
  • Anonymous Sep 05, 2008
    my pc searching for drivers for w270
I have aw270 how can i get themes and games?
Posted on Oct 01, 2008
  • 94 Answers
Connect with gprs class 8 (1u/4d) tyhas only way 2 connect. just visit motorola site. reply me
Posted on Jun 08, 2008
How to download and install internet cafe timer i have 6 unit and 1 server pls help me sir and ma'am.
Hello! try to find in google.com you need computer technician for that business, the requirement for your unit must be complete set., Prepare for ur needs : * router * RJ45 * UTP Cable * Internet Connection he need to make an IP AD each unit..
May 30, 2011 | Computers & Internet
Sir when i am connect my nokia2626 mobile phone to pc via nokia pc suit when it's not work correctly and the main proble is that when i want to connect my pc to internet using my phone then message shows...
Hi!
You have to select the mode of connection.. through blutooth or by usb data cable.
If by blutooth, you have to stable the pairing of the phone and the pc.. You also need to make sure that your phone has already the settings that your phone provider has sent you to access by phone.. If you can access the net from your phone then its ok to surf internet on your pc via phone as your model.
You also will need to set your phone as your modem.. how? go to control panel and select Phone and Modem, there set up the phone as modem.
If this things are done, then go with your pc suit again and try connecting.
If you are trying to connect via usb data cable.. you will need first to install the driver of your cable before you can start pairing your phone to your pc via pc suit.
I hope i gave you a better idea with that.
Much appreciated if you could rate this help. Thanks
May 19, 2010 | Computers & Internet
I want to connect my nokia moile phone to internet,i try to do but it doesent wok
its so simple dear .....
u need is a pc & data cable & a pc-suit
install the pc-suit then it will tell u to connect the cell to pc then follow the instructions ... & after complition just restart ur pc once & then connect ur cell to pc & then see in task-bar u will se pc-suit icon right click & there is a option dial-up just click it & here we goes now ur cell is connected to net
but keep in mind there must be internet activated in ur SIM card otherwise u r not able to use internet ....
got it ...... plzz if u have any problen be frank to tell me
Sep 23, 2009 | Nokia 5130 Cellular Phone
Ethernet on DELL 4550 with TP-link doesn't work
pinging 127.0.0.1 just tells you that your network card is operational and reacheable by your system.
I have a couple of suggestions - check them out and let me know what you found out.
  • Go to Network Connections / Local Area Connection / General Tab / Properties / Internet Protocol (TCPIP) (from the list)/ Properties. Are all settings set to "Obtain automatacally..."?
  • Is your operating system Windows XP Home or Professional (with Service Pack 2 installed)?
  • Have you installed the AirPort Utility software that came on the CD? (Check Start > All Programs > AirPort)
  • You have to have the software installed in order to setup the router.
  • What is your internet connection: Cable or DSL?
  • Take a look at this document "Designing AirPort Networks" which is also on the CD that came with the device. If you don't have it, here is the download (link). Go to page 25 and follow the instructions for PPPoE (if you have DSL service) or DHCP (if you have cable service).
Let me know how that works for you and if you have any more questions, just come back here and leave a comment - I'm happy to look further into that if this did not work for you.
May 27, 2009 | Dell Dimension 4600 PC Desktop
How to use 2900i tata set to internet in xp window
Dear
my self Akhil Gupta and I am also use net thru 2900i
so may be i can solve ur problem.
the procedure to connect internet thru 2900i is as follow:
1. Conncet ur mobile with data cable.
2. Go to ur Control Panel & Open Network Connection.
3. Create a new connection wizard.
4. Connect to the internet
5. Set up my connection manually
6. Connect using a dialup modem
7. ISP Name what u want
8. Phone Number #777
9. Username internet
10 Password internet
11. Finish
this is the complete procedure
& after use this procedure u have any more problem then contect me on my email ID akhilgupta29@rediffmail.com
Mar 09, 2009 | Compaq Computers & Internet
INternet connection
install drivers for lan card
open run cmd
ipconfig/all
it will show u ur ip adress
then ping to gateway
Jan 27, 2009 | Dell Ethernet Card Network Adapter
How to connect Motoyuva W270 with PC for internet purpose?
Hello, I just confirmed with Motorola customer care, sicne I also faced the same problem. It seems the Moto W270 does NOT have a modem (hardware) hence one CANNOT access internet on the PC via the data cable, internet access is possible only on the handset and not on the PC
Jan 09, 2009 | Computers & Internet
How can i connect my internet with my n70 to my laptop
check whether u install ur pc suite properly or not.follow these steps.
1)connect ur data cable to ur phone and laptop .
2)a icon shows connecting of ur phone
3)click pc suite icon on ur laptop .the click connect to internet.click on settings change ur operator according to ur sim card.
Apr 27, 2008 | Nokia N70 Cellular Phone
"Please insert a disk into drive.. "
  • u can install lg internet kit from " wowlg.com" then u can connect with ur USB for connectivity,
  • for connecting internet u need to select 'com port' option instead of mass storage .
  •  or if u want to trfr data from mobile to PC or vice versa u can selecrt the option of mass storage , then automatically ur h.set wil restart,u wil get the option USB "ON" on ur mobile. u wil get new link in ur PC "removable device " in option My computer, open that to trfr data.
Oct 22, 2007 | LG Shine KE970 Cellular Phone
How to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem?
This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet.
something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection.
If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
Oct 14, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Motorola Mobility W220 Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
