Question about Kenmore 22422 Top Load Washer
I need help also.
Dear Guru,
I just had the similar problem with my 7-year old Kenmore 70 series (can't find the manual although I bought it from Sears, so don't know exact model number now, may check it out somewhere). Yesterday, I found it not draining nor spinning after washing, then I found the coupler under the top for that lid pin was broken, and one screw was missing, too.
I can do many repairs including electrical things if I know the structure and how things work. I'm thinking of buying a coupler and hope to get your advice to see if I can fix it. Otherwise, I may have to buy a new one as I don't think spending $200 or so on a 7-year old washer is worth the money. What do you think? Thanks.
Patrick
  • 3 more comments
  • Patrick08 Jun 03, 2008
    Thank you, Guru, for the kind reply and info. Actually I found out that the lid switch itself still works well, but the whole assembly fell off because the two plastic screw sockets broke. Now, I'm just duck-taping the lid switch to its place so that when the lid is down, the machine drains and spins ok. However, the tape tends to get loose and then the lid switch stops function. I'd like to replace the switch but have no info about how to access where the swich is connected to. I'll find the model number later and see if you have the info about what part to order and how to replace it. Or if you know any contractor in this area (zip 08619), I'd appreciate it if you can provide the info. Thank.s
  • Patrick08 Jun 05, 2008
    Hi Guru,
    The washer is Kenmore 70 series, the model is 110 22712 100, Type III. Please help me find the right lid switch replacement for this model. Thanks a lot for your advice.
    Pat
  • Patrick08 Jun 06, 2008
    Dear Guru,
    My Kenmore 70 series washer's model number is:
    110 22712 100
    Type 111
    Please advise what lid switch part to purchase and from where. Thanks.
  • Patrick08 Jun 16, 2008
    Hi Guru,
    I'm happy to report that I fixed it using your advice. I purchased a lid switch online and installed it within about 30 minutes. Putting back the washer outer shell took about 10 minutes, otherwise it was easy and fun. Thanks.
  • tcrazy7 Aug 20, 2008
    im a single mom and i dont know to much about repairs. I have an 80 series and cant figure out how to lift the lid.
Is a lid strike permanently attached to a lid switch or the two are separate? It would help a lot if you can show a picture of each part and tell me where to purchase?
The machine and model is:
Kenmore 70 series top load washer:
Model 110 22712 100
Type 111
Thanks.
Posted on Jun 09, 2008
  • 5,911 Answers
The model number should be located around the tub opening somewhere. The part you are describing sounds like the lid strike and/or lid switch. If you can doublecheck and provide me with a model number, I can locate the parts for you. If you wish to repair this yourself I have step-by-step instructions at the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch usually costs about $25, while the lid strike costs about $10. A repair of about $35 may change your mind about buying a new one. I hope this helps you. Post back if you have further questions, or need more assistance.
Posted on May 08, 2008
  • Jeff Rockwell
    Jeff Rockwell Jun 03, 2008
    I can assure you, that you don't need a contractor to replace a lid switch. This is a simple repair job that can take minutes if you follow the link I posted for you above. I also mentioned how you can identify where the model number is. The steps are simple, the switch doesn't cost much and it will take you little time. When you find out how simple this is, you're going to hate yourself for putting off for so long. Sorry...I don't know of any contractors, but if you still need assistance please let me know.
  • Jeff Rockwell
    Jeff Rockwell Jun 16, 2008
    Patrick08,
    Glad to have been of assistance. I'm glad you were able to solve your problem with minimal effort and cost. This was an easy fix. If the advice fixed your problem, why only a "Helpful" rating? Is there something more I needed to assist you with?
    To whoever "Guest" is:
    The lid strike is a separate piece that attaches to the LID. The lid switch mounts UNDER the washer casing. The lid strike activates the ld switch through a small opening along the rim of the wash tub by pushing down on the contacts when the lid is closed. All your parts can be found at searspartsdirect.com. Just type in your COMPLETE model number and there will be a list of parts on the next page, along with helpful drawings to assist you in locating parts and how to assemble.
What year was my kenmore 70 series heavy duty washer made Just bought a house and the washer came with.
it is approximately 10 years old.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 13, 2010 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
I have a Kenmore 580.53701300 dehumidifier (70
Jim,
I have this dehumidifier and the owner's and parts manuals to go with it.
I will scan them and email them to you.
Hope this helps!
Jamie
Jul 31, 2009 | Kenmore 53701 Dehumidifier
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore 70 Series - 2 years old. Won't dry clothes, but there is definitely heat. Had a similar problem a year ago and ended up being a bird nest in the vent piping. I took off the vent piping nearest the...
Check for lint build up in the flex pipe connecting the dryer to the vent pipe..
While it's disconnected clean the duct on the back of the dryer..
A great lint cleaner is a "webster duster" on a pole...you can get alot of lint out with one of these..
k
Jun 18, 2009 | Kenmore 63942 Dryer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 70 series
You will need to replace the motor coupler. Go to Appliance Guru for details of replacing this part
Jan 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Kenmore 22422 Top Load Washer Logo
572 people viewed this question
Sal De
fordexpert
Robert Rankin
