Question about JRC 1500 MKII Radar
Raymarine 41xx - Message "bearing pulse error"
Have 41xx radar with 48" array, powers up and shows targets for 15 seconds than the array will stop spinning and a get a message :bearing pulse error". Any help
  • Anonymous Jun 23, 2008
    I am having the exact same problem, not sure when you posted but did you ever have any luck fixing the problem?
  • Anonymous Sep 02, 2008
    Same problem?
    Scholar:
  • 111 Answers
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Posted on Jan 22, 2010
What is pop radar
When radar detectors proved easily capable of sniffing out radar from miles away, radar gun manufacturers responded by producing instant-on radar or unoffically called "Pulse" radar. In the instant-on mode, the radar's transmitter is placed on hold, ready to fire but not yet producing a signal for detectors to hear. The officer waits until his target is very close (brings a new meaning to "wait till you see the whites of their eyes") then releases the radar from stand by mode and gets a speed reading within a second or so (pulse). In this situation, no detector offers much warning.
There are guns out there that operate just like the instant-on guns of the past but with a very tough twist - POPTM mode! This gun is a normal K and Ka band radar gun detectable by most radar detectors made in the past 30 years, until this gun is placed in POP mode. When the gun is in POP™ Mode and activated, a brief burst of energy, less than 1/15 of a second, is transmitted and the vehicle's speed is quickly acquired. A detector without POP™ Mode detection capability cannot respond to this brief transmission.
TIP - When traveling in unfamiliar highways always try to find a vehicle which is traveling at the same rate or faster than you are and keep several car lengths behind them. This way the other vehicle can "flush out the radar".
Oct 22, 2015 | Vehicle Parts & Accessories
Raymarine radar won't power up
Check the wiring to the scanner, eventually test with a multimeter the volt at the scanner, so to find out if the scanner is getting power.
If wires testing reads ok, then probably you have a faulty scanner, and you need to replace it.
Sep 14, 2008 | Boating
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
Oct 27, 2009 | JRC 1000 MKII Radar GPS Receiver
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Jun 15, 2009 | JRC 1000 MKII Radar GPS Receiver
Raymarine SL70 Radar; Unit switches on normally, but there is no radar image appearing. The cable is ok, the scanner is rotating...
I have the same problem. All functions and settings appear to be working OK but no image. After startup time about 3.5 amps are drawm When I turn on power [transmit] amps goes up to 4.5 approx.
I have the scanner head spinning but no target images
Ian
Apr 07, 2008 | Raymarine RL70CRC GPS Receiver
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
GPS Logo
485 people viewed this question
Top JRC GPS Experts
David Burbee
David Burbee
Will Halftowaite
Are you a JRC GPS Expert? Answer questions, earn points and help others
