Question about Cell Phones
Lcd display is not clear it has lines in the top half the dottom hald is like it should be
  • Anonymous Jul 07, 2008
    given to the vendor for repairing
ON my k850i there is a line on the top of the display.How can i remove it?
Posted on Nov 20, 2008
Top half of screen is mostly blurred out. I can only read what is on bottom half of screen. I held the button down to reset it a couple of times and it is not helping. I also recharged it.
It seems the Display screen (LCD) of your device is damaged. you can reconfirm by resetting your phone to default settings. If resetting the phone does not make any difference I am afraid to say that you will have to replace the display of your device.
Oct 26, 2016 | Cell Phones
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Nov 24, 2013 | Sharp LC 37A63M 37" LCD Flat Multisystem...
On my huawei u7519 phone the screen has no cracks. The problem is that it only shows half the screen (top) and the bottom is black and white lines.
Broken ribbon cable or internal display matrix wiring. I would suggest finding a qualified service to fix it.
Apr 03, 2011 | Cell Phones
Screen comes on but one half is black and the other half is not clear
This is a main problem in the slide model.The flex of your phone is damaged or loose.You have to replace the flex of your phone or some times it will have loosed contact...This will solve your solution.Since your able to get half display which means LCD is 100% working and its IC's too....This is caused because of constant sliding of the mobile
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 29, 2010 | Samsung SGH-A877 Impression Cell Phone
Colored lines appearing from bottom to top of the screen.
the LCD is a very complicating device for all CP. you may check it by disassemble it to it's LCD and connect the ribbon wire/flex of the LCD firmly... but this problem is best to replace it with a new LCD... very complicated device indeed
Jun 03, 2010 | Sony Ericsson w580i Cellular Phone
Cellphone - black screen
There is a LCD strip (Bunch of closely punched wires, that makes up a connector). If you have replaced the LCD yourself them there may be chances that the strip is not properly punched. That strip comes out of display and goes straight onto the main circuit board.
This is a common issue that makes the Phone works perfectly but in a black-out mode.
I hope you have a clear picture now.
Regards, Waqar. If I was helpful, Kindly do Rate!
Oct 12, 2009 | Cell Phones
Lines on my display screen too.
More than likely you will need to replace the LCD screen. When it got wet, it probably damaged the LCD screen. Usually it justs blows them completely out.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is extremely easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the 580i LCD display and links to buy the screen.
Sony Ericsson W580i LCD Screen Replacement
I hope that helps you out
Jul 10, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Nokia 6301 won't turn on properly..
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Feb 01, 2009 | Nokia 6301 Cellular Phone
NOKIA 6600 display
you need to open your unit and clean the connection from the lcd to the board of your phone. be careful not to damage some wire of the connector.
Nov 20, 2008 | Nokia 6600
Display screen turn half black
hi there
you need to replace the screen because that means that you liquid matrix display ( LCD ) is already busted.
hope this helps.
Jan 29, 2008 | Cell Phones
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
