Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Will not high spin
My ultimate care washer I bought new about 2 years ago will not high spin.
It will low spin in every cycle which will not take all the water out theres always a little water left in it and the clothes are soggy, then it will not kick into high spin on the high spin cycle. Any suggestions?
  • howdyadothat May 23, 2008
    My Ultimate Care II is about the same age. I am having the same problem. Sometimes I can get it to kick in to high if I remove most of the wet clothes. I have removed and inspected the coupling. It appears to be okay. Did the recommendation for the test work? I am also getting a small leak when the machine is filling. It is dripping near the pump but I can't find a leak in the pump. It stops leanking as soon as the filling stops.
  • 868 Answers
The brake assembly is failing ,try this if you can,loosen the 3 transmission bolts about a quarter inch and try it in spin.If it picks up speed than you are going to be due to have the break assembly replaced.High cost repair. :(
Posted on May 23, 2008
Spin cycle works sometimes, or does not spin hard enough to remove most of water
Many high-end washers have two spin cycle speeds. The low speed is for delicate fabrics. Yours may be stuck in the low speed. Check that you are selecting the wash cycle with the high speed spin.
If you are and it continues to spin at the low speed then your controller is most likely at fault. Your gearbox could be bad too but it usually complains with a lot of noise.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer spins slow.
Check your direct drive coupling and your clutch.
Feb 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
No high spin
Make sure you are set for normal cycle. Some permanent press cycles only spin on low. Also check that your drain hose is not kinked. If it is the water may not be draining fast enough.
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
335 people viewed this question
Dan Webster
Dan Webster
Sal De
