Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
I have a whirlpool ADP4400 the green light is flashing and the pump continues to pump but the cycle will not start
  • 3 more comments
  • telf May 18, 2008
    I have a whirlpool dishwasher model ADP 4404 The green light stays on for 5min, then it starts flashing, the motor is still running but there is nothing happening with the wash cycle.
  • Gary Rowe Jun 13, 2008
    The cycle starts, after 2-3 mins the green light starts flashing and the cycle stops??
  • aaranreid Jul 09, 2008
    hi, have similar problem
  • dcarthy Sep 16, 2008
    hello, I have exactly the same problem. Has anyone got a solution or just know what the problem is?
    Hello, I have exactly the same problem with my dishwasher. Does anyone know what the problem is? Any help would be appreciated.
    Dave
I had this exact problem with my dishwasher but i managed to fix it today. It was such a simple problem, the water outlet pipe had a kink in it and wouldnt let the water drain. I straightened the pipe, put duct tape around the kink to strenghten it and the dishwasher worked straight away. I hop this helps.
Posted on Sep 21, 2008
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Have a Whirlpool Dishwasher 6ADP 5540. Starts cycle - fills water then about a minute into it the start buttons flashes 6 times and will not continue on. Very rarely, the cycle does continue on. Have...
Hi Jodie,
An F6 fault code - indicated by the green light flashing in sequence next to the start button - is indicative of a water inlet problem.
First of all check that the water tap the dishwaher connected to is fully open. If this does not work check that the feed pipe from the water source to the appliance is not blocked.
If neither of these two things are the problem then you will need to order a new flow meter/ reed switch and this will sort your problem out.
The Whirlpool UK spare part number you'll need is 481241868368
Hope this helps
Alex
Jan 14, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool ADP4400
if this is happening right at the start of the cycle, then fault will be drain pump jammed. if it is happening after filled with water, then fault will be the circulating pump jammed
Nov 05, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
1,396 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
