HP C6180 photosmart all in one printer jam
On printing an envelope the paper jammed. I managed to pull 90% of the envelope back through the rear plate entry port. The remainder of the envelope is lost inside the roller & invisible. Any suggestions please?
  • gumtree Nov 04, 2008
    I have had a similar problem on two separate occasions with the same printer. Luckily, like you, it was within the warranty period and John Lewis were very good in sorting it out. May I suggest you use good quality envelopes in future, make certain they are perfectly dry and fold the flap within the bulk of the envelope before inserting it in the printer. Since doing this I have not had any problems.
    It is extremely difficult to find the last little piece of envelope left in the machine and there doesn't appear to be any way of unwinding the mechanism - HP ought to take note.
    I hope this helps.
    Problem Solver:
  • 3 Answers
Thank you for coming back. I decided to return the printer to the retailer as it is just inside the warrany period.
Rgds
Posted on Apr 29, 2008
I have a HP Photosmart C6180 All-In-One and the paper is jamming ever time I try to print or receive a fax.
Check the specifications of the paper size and weight. It should be a supported paper size. Clen the rollers of the paper.
Dec 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a paper jam on my HP 3210 Photosmart All-in One
When you open the back door there's a guide that pulls down and on either side of the fuser there are levers to release the pressure from the rollers, if you can see any of the envelope from there you should be able to gently and evenly pull it thru. Otherwise a shop repair to remove the rest and fix whatever caused the jam.
Sep 04, 2009 | Brother HL-2040 Laser Printer
Paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 6180 printer
henryandjane,
Look over on the wheel that will feed the paper mybe there is a tiny piece of paper on it and find the sensor for the paper mybe it is stack-up already
Jul 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP c6180 photosmart all in one printer jam
On the back of the printer there's a door.
Depress the latch and remove the door. This will give you easy access to the rollers and should give you enough space to remove any remaining paper from the jam.
Best of luck!
Apr 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper Jam
locate at the back portion of your printer there is small rectangular like a door pull up and then get those paper that causes paper jam slowly see to it that there is no paper left....and start printing again if it does not worked then try to clean your paper rollers...
Oct 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
136 people viewed this question
jasbo
jasbo
