A new colour cartidge is in the machine(the second new one)but it still will not print in colour properly.The test page is just blue and black.I have found a small grey rubber 't shape'lying to the front of the cartidge section.I can't see where it has come from. The printer is an HP 6300 series.
  • daniela2897 May 22, 2008
    Added new ink cartridges. All photos are printing with a pink hue to them.
  • Anonymous Jun 13, 2008
    red and yellow color are mixing together
    Problem Solver:
  • 8 Answers
Try auto cleaning the print head.This a common problem.The ink has dust particles and blocks flow.
Posted on Apr 28, 2008
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
Blue colour is missing from colour cartidge
Something may have gotten stuck in the blue ink and clogged it. If the cartridge is new you may be able to send it back and get it replaced, If not you may just be out of blue ink.
Aug 04, 2013 | Lexmark X1270 All-In-One InkJet Printer
New ink colour printer not printing black. Prints all other colours but not black when print tested
Hi there!
If the test page from pc or the machine test page doesnt show black, what you can do is to clean the printhead. To do that press the Ink Management button on the control panel and select cleaning press ok then press the up or down arrow key to select Black press ok and press Black Start. After the cleaning process print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times.
Hope this helps Please rate if it worked Thanks!
Mar 30, 2011 | Brother DCP-585cw All-in-One Wireless...
Too much red
I'm assuming that the colour cartridge is a three in one. Blue, Yellow and Magenta.
When printing a colour document, the printer automatically balances colour mixtures from the three primary colours listed above. Should a print out be too red, its probably because its run out of yellow and/blue.
The best way to check is to print out a test page, you should get a block for each of the colours and black. If one's missing, there's your answer.
Apr 29, 2010 | Dell 922 All-In-One InkJet Printer
Installed new black ink cartridge per instructions. HP #56 - machine type hp psc 2210 all-in-one. Machine instructed how to run cartridge alignmet check. In all modes machine runs about one half check and...
to complete the alignment it needs to detect the lines printed from both the black and colour cartridges.maybe ur black cartridge is printing the necessary pattern but the colour is not printing so when it tries to read the colour paattern ,it cant read and cancels the alignment and ejects the paper out..it will keep on doing this if it cannot read the both colour and black patterns.see to it that both ur cartridges are printing and working properly.
Dec 17, 2008 | Office Equipment & Supplies
Xerox Phaser 6180 uses too much toner
In all honesty, its not that they use to much toner. Xerox does NOT put nearly enough toner in their cartridges to get the proper yield.
I have gotten as low as 200 pages out of those cartridges.
I do service on them and they do not give 1/5th the yield they advertise.
Nothing you can do to be honest. But they are hugely inefficient.
Aug 13, 2008 | Xerox Office Equipment & Supplies
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Colour is wrong
Yes seen new color cartidges bad. Machine new should be under guaranteed also if cartridge does not work...
Dec 30, 2007 | Office Equipment & Supplies
164 people viewed this question
jasbo
jasbo
