Question about Toshiba TZ50V51 50" Rear Projection Television
No sound I have a Toshiba 50 inch projection TV....The sound just stop working...I have a picture but no sound
  • 125 Answers
Make sure the external speakers are not turned off
Posted on Aug 23, 2008
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba projection tv 50 inch
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Jan 07, 2008 | Toshiba 50H72 50" Rear Projection...
I got a 50 inch TV and I cought my daughter banging on the TV screen and now there's no picture but the sound is good, please help
it damaged the crystals in the LCD Panel the only way to fix it to take it back to where u bought it and tell them the screen went out they more than likely will replace it
Sep 01, 2009 | Toshiba 50H82 50" Rear Projection...
Why does my toshiba 72 inch projection tv picture freeze?
sounds like your dmd module. its the part of your optical block that processes the images that make up what is projected on your screen.. without a model # i can't tell you the part #
Mar 13, 2009 | LG Televison & Video
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
1997 Toshiba 50 inch tv
Sounds as though you have a filter capacitor bad in the power supply. I strongly suggest you have it checked and repaired soon, before it burns up a transistor or regulator. The cost may be a bit high now, but will escalate to possibly a complete power supply board. If you can repair your own set, check the main power supply filter capacitors. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Toshiba TP50G50 50" Rear Projection...
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
Green Picture
It a picture tube issue or a crt driver issue. Not something a layman can repair unless they have the training as well as the equipment to repair solid state TV sets.
Sep 11, 2006 | Toshiba 50A50 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
