Question about Lucent CellPipe 20S Router
Ip assigning I tried to assign static ip to the router.But i failed on doing that.Can you please help me to trouble shoot this.Thanks in advance
  • Byron Wells May 11, 2010
    What type of router?
    Novelist:
  • 144 Answers
Hello!
-- what is the exact model number of your router?
-- the ip address that you are trying to assign to your router, is it provided to you by your isp?
-- what is your nrtwork setup?
1. try to reset the router and try again to assign the static ip address.
2. make sure you will input all ip address correctly including the subnet mask, gateway and dns numbers
3. if its still not working try to upgrade the firmware or software of your router, maybe its corrupted thats why its not accepting the settings
Posted on May 01, 2008
Where do i get the ip address for my jvc lt-40tw51j
IP addresses are normally assigned by the router in the network that you connect to. They often change each time the device connects. If you need a static IP for the set for some reason, the router can usually be set up to assign a specific IP to the device by entering the device MAC code into the router and assigning it a static IP. Then, each time the set comes online, that IP will be assigned to it.
Nov 02, 2015 | JVC Televison & Video
WRT4G2 VI wireless router. I was upating the firmware when the power flashed. I have no access to the router's gui and the router is not broadcasting. I am not getting a dhcp address
do a hard reset for the router by pressing the reset button for 10-20 seconds...
check whether its getting a dhcp address...
if it is still not getting an ip address, then try to assign a static ip address in the range of your router on your computer...
for example...
The default ip address of linksys is 192.168.1.1.............
then assign
IP address 192.168.1.5
Subnet mask 255.255.255.0
Default gateway 192.168.1.1
Also assign a static DNS
Primary DNS : 8.8.8.8
Secondary DNS : 8.8.4.4
Now try to open the GUI of your router...
Dec 10, 2010 | Linksys WRT54G2 Wireless Router
CANT CONNECT TO PLAYSTATION NETWORK. SIGNS ME OUT WITH ERROR 8002AD3D. PLEASE HELP
try setting up the ps3 using static ip address.
the subnet mask is usually 255.255.255.0 and check your DNS server in your router to input it in your ps3 cause it can vary.
Next, you can open the ports through your router 80TCP, 443TCP, 5223TCP, 3478UDP, 3479UDP, and 3658UDP all assigned to your ps3 static id address.
You can open the ports or use DMZ function(enable), which is alot easier because all you need to input is the static ip address that was assigned to your ps3.
However, i set them both up and i'm too lazy to go back to check whether it needs both or one of them, but i'm sure one of them will suffice.
Note: If you have DHCP enable, you have to check where the ip address starts and ends. You want to assign your ps3 static ip address within that range. Remember, assign a static ip address that is different from your default router ip address cause it can lead to alot of viruses.
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
Can not get my xbox to connect to my netgear 614v7 router am using a lan connection but it cant get a IP address from the router any ideas ??
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address 192.168.1.50.
Click On 'Apply'.
10. Log Out of the Router Page.
Please repeat Steps 3 – 7 to configure the ports “UDP/TCP 3074”.
Jan 03, 2010 | NetGear WGR614 Wireless Router
Connecting NETGEAR Wireless RouterWPN824 v2 to PC HP2009m tru Comcast Airrs Modem for use by Xbox360 in another room
the Router.
Address as: 4.2.2.2
port as 88.
7. Hit ‘Apply’.
Click On 'Apply'.
Dec 30, 2009 | NetGear RangeMax WPN824 Wireless Router...
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
Xbox Live connection problem
the Router.
Address as: 4.2.2.2
port as 88.
7. Hit ‘Apply’.
Click On 'Apply'.
Apr 13, 2009 | Zyxel Prestige 334 Router
I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Dec 08, 2007 | Computers & Internet
Static IP on machine, now can't access web sites
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Lucent CellPipe 20S Router Logo
125 people viewed this question
Top Lucent Computers & Internet Experts
John Anderson
John Anderson
D. E. Hev
Tom Chichester
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
