When i put my hardrive in my pc it makes my pc hang and freeze maxtor S728080PLAT20 also what are the jumper settigs to make it the slave drive thx
  • 106 Answers
Remove all the jumpers and this drive will become slave.
Posted on Apr 28, 2008
Slave Harddrive I have an extra harddrive that I wish to install as a slave, unfortunately I cannot at the moment, due to some problems. First, the current harddrive I have is a Maxtor I believe, and it...
Dear soviet guy
these are the jumper settting for both the drives
please check that they are on the right place before if you want to use seagate as a slave try placing the jumpers as mentioned.
Maxtor Jumper Settings
Seagate Jumper Settings
Thanks
GAGAN GUPTA
Mar 17, 2011 | Microsoft Windows XP Professional SP3 Full...
My maxtor hardrive makes anoise wen it is pluged in by way of usb
put in a new hard drive & yours old hard drive in your computer and make the old hard drive as yours slave.
Jun 30, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
I need to make my Maxtor a slave but i dont know
Refer to the following schematic and put the jumper. Also make sure that your harddrive is detected and in the system BIOS.
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
Thanks for using fixya
proton
Sep 24, 2009 | Maxtor Hard Drive
Installing old maxtor HD on newr pc, have to change it to a slave
J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
Jul 26, 2009 | Maxtor Hard Drive
Where do i place the jumpers to set a maxtor model 53073U6 to run as slave?
See the sticker on the HDD. There is written the pins, you have to put the jumper.That should be on the 2nd set from the IDE end. Just removing the jumper should make it slave too. Run it without jumper. Thanks
Jun 05, 2009 | Maxtor Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Maxtor hardrive
If one of the jumpers shorts two pins and the other jumper is a single pin short, remove the two pin jumper. The single pin jumper should be located on the pin at the far upper right corner. should be set as a slave at that point.
May 26, 2008 | Maxtor Hard Drive
Slave drive
if you do know how to install hardrives to your computer, this will be fairly simple.
check the back of your hard drive and look for the pins. there will be a connector there that will indicate if the hard drive is a master or slave. put the jumper into slave.
after doing that. connect your hard drive to the ide cable. since it is a slave hard drive, put it in the 2ndary ide slot on that cable. you can either do this on the primary ide cable or the 2ndary ide cable.
restart your computer.
done
Mar 22, 2008 | Maxtor Hard Drive
Computers & Internet Logo
David Payne
David Payne
