Question about Lands Phones
Model kxtg6700 with 6 remotes\had 1 hour power outage/ all units power on /but does not pick up telephone lines/ all lines are working/
  • rojan5050 Apr 28, 2008
    unit seems locked out, spkr light on only
    Master:
  • 788 Answers
So you're saying that the base station works with your lines but none of your remote handsets are working right? You may just need to re-mate them with the base station.
The manual is available here: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
Follow these instruction from page 54 of the manual:
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base unit,
register the handset.
Important:
If you have already deregistered the
handset, perform steps 2 and 3 only.
1 Handset:
{MENU} ->i {0}{0}{1}
2 Base unit:
Press and hold {INTERCOM} until the
IN USE indicator flashes.
After the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Posted on Apr 28, 2008
  • Dean Joly
    Dean Joly Apr 28, 2008
    Try unplugging the power then plugging it back in on the base station, this resets it. If that still doesn't work then your base station has a problem. If it's under warranty have Panasonic repair it. If it's out of warranty, it would probably be more expensive to repair then to replace. You could try to find another base station that uses the same extension handsets.
  • Dean Joly
    BTW? Does the speakerphone in the base function?
    Genius:
  • 1,142 Answers
Please be bit specific about the problem
Error 350 - how do I fix this?
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
However under rare conditions incompatibility between the two machines may cause the remote machine to simply get this code.
Try these steps...
1. Press setup, and then go to TOOLS.
2. Press okay on TOOLS, then look for RUN FAX TEST. Then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, and then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Also you can try to reset the printer.
1. Take out the cartridges from the unit .
2. Make sure the unit is connected to the wall jack directly without any surge protector.
3. Unplug the power cord from the back of the unit ( without turning off the unit ) .
4. Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5. Do not release the keys after a few seconds you will find the hp logo or bars moving across the screen .wait while the unit turns off.
6. After one minute turn on the printer . It will go into alignment phase > let it finish .
7. After its done > try to make a copy .
Note - you can also try the OK and CANCEL key combination in place of # and 6
Jul 18, 2011 | HP Officejet 6500 Wireless All-in-One...
Error 351
The reason for this error code is :
•The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
•The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
•The remote user pressed the Stop key while the reception was in progress.
•Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions what you can try :
•Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
•Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed
For more details you can check this link out :
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549&lang=en&cc=us&taskId=101&contentType=SupportFAQ&prodSeriesId=351105&prodTypeId=18972#Error344
Nov 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
We seemed to have a power outage over the weekend. We have M7324 system with 6 rollover lines, only the first two work now, the other four are not working. I rebooted the system, no change. Can you help?
You must have an older system. There is a battery built into the control unit (not user replaceable) that stores the system programming in case of a power outage. When the battery is dead, your system will lose all programming and default to assigning the first 2 lines to all phones. The system will have to be completely reprogrammed.
Please Note: Now would be a good time to install a UPS/Battery Backup unit on the phone system. I recommend a large enough unit to keep the phones running for at minimum of 2 hours during a power outage. Install the UPS/BB first, and then reprogram the system (so it won't have to be reprogrammed twice). Good Luck!
Aug 02, 2010 | NorStar M7324 Corded Phone
Power outage overnight. Now, Onkyo TX-SR603X no
Depending upon the type of power outage, you may have more of a confused receiver than a defecive one. Try unplugging the unit for an hour or so to see if that resets the whole thing back to "normal". If not, then further investigation with a scope or logic analyser will be required to determine whether the problem is with the internal CPU or a defect on the data lines. Unless the reset works, this is not likely to be a DYI repair.
Dan
Mar 28, 2010 | Onkyo TX-SR603X Receiver
After power outage remote not working.
Hi, this is a bit basic, try turning of for about 1/2 hour, to enable to discharge, then try again.
( I have used this on industrial installations, with far to complex computers stuff inside, and that mainly works)
Apr 02, 2017 | Sanyo DVW-5000 DVD Player/VCR
Lost power for one second and now cannot get my caller ID to work
unplug the telephone cable from the back of the receiver and plug it a basic telephone to check if there is a dial tone. if there is a dial tone restart the receiver without the the telephone line plugged in. after it loads and u have a picture, plug in the telephone line. call the home to check. if its not working the modem in the receiver has gone bad.
Oct 20, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Telephone not working,
you may need a new telephone modem if you have VOIP service. Mine got zapped during a power outage and it ended up I needed a new TA
Dec 29, 2007 | BellSouth GH5831BK Cordless Telephone
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Nov 19, 2007 | Samsung Prostar 816 Phone
At&t 1739 answering machine
Get remote access code from the machine get it by pressing set up button on answering machine. Go to another phone when machine picks up enter access code then enter *7 record new message press 5 when done then to end call enter *9
Sep 18, 2007 | Lands Phones
AT&T EP5962 (5.8GHz digital Plus 2 Line)
Try unplugging your corded base unit, then replug. It should reset. Then you'll be able to go in and delete those messages.
Sep 02, 2007 | AT&T EP5962 Phone
Lands Phones Logo
125 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
