Question about Sony KP-46WT510 46" Rear Projection HDTV
9 blinks I was wondering if anyone can help me out. My daughter unpluged the tv while it was still running. Now it will not power on. The standby button blinks 9 times. Any idea whats going on with it. Thanks, John
  • jsmac112 Apr 28, 2008
    is that something your average person can fix, or does it need to be fixed by a professional? Do you know what something like this costs to replace?
    John
  • weezie101 Apr 28, 2008
    tv blinks 9 times and does nothing else
  • 121 Answers
I looked up blinks for your tv and if unplugged while playing its commen for either Ic708 to be faulty or more common your ps701 or 702 is open on your A board and will have to be replaced
Posted on Apr 28, 2008
  • dawn garrett
    dawn garrett Apr 28, 2008
    to be honest a tv repair shop will usually tell you to replace the A board because most wont replair at component level cause not enough profit for them, If you can solder you can do the repair yourself you can go to the website I posted below leave them an e-mail stating you need the sony repair kit for 9 blinks and include your model number, they do sell the repair kit I looked for $85.00 and comes with your parts you need and full instructions on how to remove your board and how to do repair diagrams and also free online instant messaging tech support while you are doing your repair incase you run into a problem and if you don't feel confident doing the repair yourself they do sell the boards also but leave what you need in the e-mail and they do get back to people usually very quickly I have used this sight several times myself
    http://servicemanuals.vstore.ca/
Sharp aquos TV lc-42d64u has blinking power light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2016 | Sharp Televison & Video
My Sony tv won't power on its goes on then stays blinking on standby 14 blinks on red
Try unpluging the tv for several minutes and then plug it back in and turn it on and see if that helps
May 22, 2015 | Sony Televison & Video
Hi there, I wonder if anyone can help me. I have recently bought a Sony Bravia 32L40 and on occasions I get the following weird problem: after switching the TV off via the remote, it seems to go into a...
The TV is going into protection mode, possibly due to overheating.
Re-read the installation instructions to check how the tv should be installed, there will usually be advice regarding keeping case vents clear fro obstructions and no closer than "x" distance to a wall or obstruction, and also advice about not putting the tv in a hot sunny location or next to a heat source.
If you eliminate those environmental causes, then the tv is faulty and should be returned for refund or replacement. overheating puts stress on other components and prematurely fatigues them, so as the tv is fairly new try to strongly resist any offer of a free repair as in due course your example has a higher than average chance of going prematurely wrong again.
Jun 24, 2011 | Sony Televison & Video
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony tv wont turn on, standby light just flashes
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Nov 18, 2007 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
