Question about Kenmore 72602 Gas Dryer
72602 kenmore dryer
Doesn't heat
  • jacksoncharl Jul 27, 2008
    I replaced the dry with new ig-niter but before I replace the gas valve please let me know if the problem could be a sensor.
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
3 Suggested Answers
danromarris
  • 101 Answers
SOURCE: dryer won't heat up
It could be the problem, you are definitely on the right track. There are a lot of things though that could cause a dryer to not heat. I try to give the most common reasons as it is hard to determine without hooking up a voltage meter to the parts. One thing is that your vents may be clogged up somewhere between the dryer and the outside. A lot of people don't want to believe that the problem is that, but it is common and if that is the problem better to be that then something wrong with the dryer. Anyway, check outside where the vent is and feel if the air coming out is strong. If it's not that may be the issue.
Next, if the air is good, open up the bottom panel so you can watch the dryer working. Watch and see if the ignitor is coming on. You may just have a problem with the thermostat which tells the dryer when to shut off the heat when the temp in the drum has reached the max. It should go up to about 110 degrees and then turn off, when it gets down to about 70 or so it will come back on. That is the job of the thermostat, to regulate the temp. If it does not work though it just won't heat.
If your ignitor does come on and you see the flame and it goes right off then you need to replace the thermostat. If it doesn't come on at all though you will need a new ignitor seloniod. Let me know if you have any other questions and let me know if this was helpful for you. It might be wise to have a tech come out and fix it too as some of those things can become quite a pain to fix. Gas dryers are a lot more complicated then electric. Good luck and glad to help.
Posted on Jan 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Kenmore 72602
It is an easy repair. The sensor and ignitor are ok since it will work one time when it is cooled don. The problem is with the coils. They get hot and quit. Common failure on gas dryers.themobilian_150.jpg
HOW TO REPLACE
Posted on Nov 16, 2010
My dryer kenmore elite 11074972300 doesn't heat
I had this problem with one of my dryers and it turned out that the heating element was broken. It is a repair man that you need now I'm afraid.
Nov 04, 2012 | Dryers
Dryer not heating gas may have gotten turn partially off does the dryer have a pilot light
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Kenmore 72602 Gas Dryer
I have a Kenmore 72602 dryer, my dryer starts fine, but after about a minute the burner turs off and there is no heat, What causes this? is it an easy repair
HOW TO REPLACE
Nov 16, 2010 | Kenmore 72602 Gas Dryer
Start button starts dryer but it stops when I release button
if there's an even heat board in the top console change it out,also there are two relays in the top console one is for the motor and the other is for the heat,they are the same,you can swap them out to see if the relay is the problem but if there's an even heat board that will most likely be it.next time send model number and i can give you the correct part number,let me know how you make out
Jul 24, 2010 | Kenmore 72602 Gas Dryer
It starts and the tub turns but it won't ignite and heat up
The ignitor for the soark is at fault. You should hear it make a clicking noise upon starting it. If not the ignitir is bad
Apr 05, 2010 | Kenmore 72602 Gas Dryer
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
No heat to dryer
it mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
Dec 04, 2008 | Kenmore 72602 Gas Dryer
Kenmore 72602 Gas Dryer Logo
188 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
