Compaq presario 1500 ram memory
Installed 1ghz after installing 2- 512mb still geting 480 mb any sugestions
  • notorious124 Apr 29, 2008
    THE BOARD DID EXCEPT IT. EVEN TRIED 2-512MB AND STILL GOT 480MB THEN TRIED 1GHZ AND STILL GOT 480MB ALSO TRIED USEING DIFFERENT SLOTS STILL 480MB BOTH SLOTS ARE WORKING COULD IT BE IN THE BIOS
I had the same problem and no luck solving it until today. Found 2 512 MB A-DATA DDR333 SoDimm and now I get a display of 992 MB of RAM + the 32 MB of the "onboard" graphics card, adds up to total of 1024 RAM. So, there is still hope for us all.
Posted on Feb 25, 2009
    Genius:
  • 3,587 Answers
Only thing that comes to mind is that board won't accept the larger memory configuration. did you check on that prior to buying and installing the memory sticks.
Posted on Apr 28, 2008
I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
Please rate this reply - good luck!
Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
Which ram support for compaq presario c700 tu''
This laptop can have a max of 2Gb of ram, (2x1gb)
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot, None-ECC
Hope this helps.
Aslong as you get 512Mb or 1Gb sticks of PC2-5300 none-ecc laptop ram, you will be fine.
Jan 02, 2010 | Compaq Presario 700 470024-192 Notebook
I installed 2 new banks of 512 MB RAM in my COMPAQ PRESARIO S3000NX. The COMPUTER PROPERTIES SHOW INSTALLED RAM TO BE 480 MB ( Not 1GB as I expected) Why is this happening? George McGeachie...
Your bios may need to be flashed so your motherboard with recognize the ram. It also may be fixed by adjusting the speed of the ram in your bios settings. Be carefull and read about doing both of these procedured in your mainboard manual( should be able to get a manual from the compaq site if you do not have one).You can mess up your computer real good if things are set or flashed wrong. Good Luck
Nov 22, 2009 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Have a compaq presario sr2170nx....installed 1 gb memory but not showing up. swapped the memory sticks positions and restarted but still wont show up.
If you do not get the right memory for your computer it will not work. the memory you need is listed in the table below. And pay attention to the max amount of ram. Your system can only hold 2 gig and it comes with one gig installed
Component Attributes Memory Installed 1 GB Maximum allowed 2 GB (2 x 1 GB) Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM
Jan 14, 2009 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Added memory but one memory card (Original) not recognised
OK, according to Crucial.com your RAM does need to be installed in matched pairs.
Here is a link for your computer information:
http://www.crucial.com/store/listparts.aspx?model=Presario%20SR1460AN
If you get another 512MB module and install both pair, it should work well.
Jan 13, 2009 | Compaq Computers & Internet
Upgrade ram on 12XL125
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory
This system will not be able to use the ram you are trying to install.  For more about this system go to this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013744&lc=en&cc=us&product=95040&dlc=en
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
RAM replacement of Compaq Presario V2000
you'll need to go to www.hp.com and ask that question in the accessories area...
Mar 08, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
