Philips 32 LCD TV 32PF9541 Black Screen
I bought a Philips LCD TV model 32PF9541 4 months ago. About 4 weeks ago the screen started to go black while watching the tv. The sound stays perfect and I can still change the channel and hear the channel change but the picture stays black. I tried it with a DVD and had the same issue so it's not my satellite connection. I also unconnected and reconnected all cables a number of times but this did not help.
On some occasions it does work. If you power on and off the TV a couple of times it usually fixes itself but it is happening more often now and on a bad night it will go black every 30 mins. I have taken it back to the shop and they are being particularly unhelpful. They have said they can not replicate the fault in the shop but I am very nervous about taking it back as I don't want the warranty to run out.
I would be really grateful if someone could let me know if this sounds like a technical fault with the TV or something I have done as although I tried a number of things to fix it, the shop are making me doubt the problem.
Thank you,
Paula
    Scholar:
  • 72 Answers
Sounds like a temperature problem if it takes a while for the problem to happen there are several things u can try and figure it out yourself. 1. Remove the back cover of the tv and turn the tv on. 2. use a hair dryer and apply heat to various boards of the lcd (inverters, power supply and scaler) while applying heat to see what board reacts and makes the tv go dark. More than likely its a defective LCD panel and its just as easy to send it back and get a replacement TV.
Posted on May 02, 2008
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
I have sound but no picture. 42" plasma. i bought 4 years ago. last week the botom half of the screen started flashing back and forth between the picture and all black, but we just came home and now it is...
Sounds like you need a lower Y-DRV/BUFFER board (996500032640) and a Y-SUS board (996500032643). Part numbers listed are for models which use a Samsung Panel.
May 10, 2010 | Philips 42PF9630A 42 in. Plasma Television
I have a 46 inch sanyo lcd 1080p that is only 2 years old. A few months ago we started getting a black screen only on part of the tv. It would show up off and on. some days all the time and others not at...
I'm having the same problem with the same TV. I called around to repair shops and I guess it's fixable. Haven't taken it in yet but I was told it most likely is a bad module. But this seems to be a really common problem with this television
Feb 04, 2010 | Sanyo DP32746 32 in. LCD Television
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Televison & Video Logo
1,001 people viewed this question
Top Televison & Video Experts
