In trying to attach our router to set up wireless service on a cable network.. We can not determine where to connect or what to connect to.... The TOWER cable modem... or the computer Modem.Acer KDS........ new but... Please help us
  • cnan32 Apr 28, 2008
    Whatt is the ethernet card
  • 26 Answers
Normally the incoming cable is connected to the cable modem... connect cable modem to wireless router... connect router to pc ethernet card
Posted on Apr 28, 2008
  • bigestalever Apr 29, 2008
    the ethernet connection looks a bit like a telephone jack...older pc may not have one....you can either install one or use the usb connection
How do I connect the router to the computer? does the computer need to be connected to the internet at the same time? does the USB adapter needs to be plugged in for the set up?
1) Choose a convenient location to begin installing your router such as an open floor space or table. This does not need to be the permanent location of the device. Particularly for wireless routers, you may find it necessary to re-position the unit after installing it as the cables / signals may not reach all areas needed. At the beginning, its better to choose a location where it's easiest to work with the router and worry about final placement later.
2) Plug in the router's electrical power source, then turn on the router by pushing the power button.
holygrass_1.jpg (Optional) Connect your Internet modem to the router. Most network Modems connect via an Ethernet cable but USB connections are becoming increasingly common. The cable plugs into the router jack named "WAN" or "up link" or "Internet." After connecting the cable, be sure to power cycle (turn off and turn back on) the modem to ensure the router recognizes it.
4) Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. Using a cable during router installation ensures the maximum reliability of the equipment. Once a wireless router installation is complete, the computer can be changed over to a wireless connection if desired.
5) Open the router's administration tool. From the computer connected to the router, first open your Web browser. Then enter the router's address for network administration in the Web address field and hit return to reach the router's home page.
Many routers are reached by either the Web address "http://192.168.1.1" or "http://192.168.0.1" Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step. And do call your Internet service provider for the default settings such as "MTU" "VCI" "VPI"
Tip:
When connecting devices with network cables, be sure each end of the cable connects tightly. Loose cables are one of the most common sources of network setup problems.
Nov 26, 2010 | D-Link AirPlus DI-524 Wireless Router
How do i connect to my computer
Are you trying to conenct to the wireless network ?
If you are trying to connect to the wireless network then you will first need to check the wireless settings of the router. For this you will needto open the set up page of the router.
Once you get the wireless settings of the router, you will need to connect to the wireless network on your computer.
If you are trying to connect the computer to the router with the cable then you don't need to change anything. you just need to connect the cable and it should work
OR
You are trying to set up the router for the Internet connection. for this you will need to open the set up apge of the router and change the settings of the router according to the Internet service provider.
Click Here for more information about the router and networking
Feb 18, 2010 | Computers & Internet
My belkin f5d9630-4 will not connect to internet through wireless only with cable attached
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Jan 11, 2010 | Belkin F5D9630-4A Wireless Router
Where do i find the essid and key on the 2701HG-B trying to get a HP Photosmart printer to attach
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 20, 2009 | 2wire (2701HG-B) Wireless Router
Dsl modem network cable attached modem icon
Are you trying to set up the router ?
First make sure that your computer is online when connected directly to the mdoem. ISP is DSL.
If not online through the modem then you should have user name and password for the ISP.
try to reconfigure the router.
Click Here for more info about router set up.
Nov 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Error code 80072745
From the Microsoft web site at: http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13931.entry?sa=240159924
December 11 Error: 80072745 If you are encountering the error code 80072745 when you sign into Messenger try the following: 1. If you are connected to the Internet through a router, remove the connection to the router. Then, directly attach the network or modem cable to the computer. This will help determine whether the issue is related to a firewall setting on the router. Try to sign in to Messenger after you connect to the Internet. If you can connect to Messenger after bypassing your router, the issue may be related to router settings. Try resetting your router (Note: This may revert your settings back to factory default settings and may delete all your custom settings.). Please contact your router manufacturer's Help documentation or customer support channels to determine how to reset your router or enable port 1863 through the router firewall. 2. If you are signing in from a corporate environment, contact the network administrator to determine whether port 1863 is being blocked inside the network.
3. If you have Zone Alarm with IM Security installed on the computer, turn off IM Security for Messenger: 3.a. Right-click the Zone Alarm icon in the notification area, and then open the Control Center.
3.b. Click IM Security or click Security to open the IM Security settings window.
3.c. Click the Main tab or the Status tab.
3.d. Slide the Protection Level slider to Off to turn off IM Security.
Note: This procedure will change the IM Security settings for any instant messaging programs that are installed on the computer.
3.e. Sign in to Messenger again to determine whether the issue is resolved.
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service.
Aug 15, 2009 | Microsoft Office Outlook 2003 for PC
NetGear Wireless-G Router - Not detecting modem/internet
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Apr 15, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I need to hook up and start using a wireless router, can i get some help starting?
hi licking;
what type of wireless router are you using? a linksys? or a dlink?
do you have color coded cables?
try this:
from your modem(the box given to you by your isp), connect a cable from your modem LAN port to the WAN port of your wireless router.
If your going to connect a pc wired to your wireless router, you can connect a cable from your wireless router LAN port to your lan card of your PC.
give more details and ill be happy to help you. :)
Jun 19, 2008 | Computers & Internet
Windows live messenger
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service. Hope that helps!
Apr 23, 2008 | Microsoft Office Outlook 2003 for PC
Computer interfacing
You have a computer (what manufacturer and model?) connected to a Netgear WGR614 wireless router (please confirm the router manufacturer and model) by wire or wireless?
If the computer is connected wireless is it with a wireless adapter built into the computer or added to the computer?
If it was added to the computer what is the manuracturer's name and model of the add-on device?
Has any other computer ever successfully connected to the internet using your router?
  • If so was the computer connected using a wire, if possible?
  • If so was the computer connected wirelessly?
If no computers were connected successfully to the router please provide the name of your internet service provider?
I also may need to know the city and state you are located in or other information. We probably need to configure the router to attach to your internet service providers equipment
The following are to determine if the internet service providers equipment has been successfully installed and the capabilities of that equipment as it may support connecting your router, if necessary, and your computer to the internet.
Were any computers ever successfully connected to the internet by directly connecting to your internet service providers hardware?
If yes how were they connected
  • USB cable?
  • Ethernet Cable?
  • Wireless?
  • If wireless what is the manufacturer and model of the internet serivce providers hardware providing the wireless service?
Dec 16, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
