Question about Sharp AL 1631 Copier
Copier trouble message H4 on screen
  • murrays May 07, 2008
    H4 flashes
    I work in a school where they are doing construction, could this be from an electrical surge? Tried turning on and off copier. Has now sat idle for 4 monthes.
Press clear, auto , clear auto alternate until it turns off, then enter the # 14 and the machine will reboot. Our machine does not say exposure it says Auto....so this may be a little clearer...That should solve the problem.
Posted on Jun 05, 2008
My sharp z-830 has H4 on screen. l known it is fusing unit not heating. l cant identify the buttons to press to programm it.
Posted on May 22, 2008
  • 62 Answers
Press clear , exposure , clear , exposure : the machine will switch off
input 14, press start and the machine will reboot.
this will proberly solved your problem
Posted on May 11, 2008
  • 2072 Answers
SOURCE: trouble code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Posted on May 06, 2008
disastertech
  • 62 Answers
SOURCE: Sharp AL-1631 copier problem
press copy. clear, copy, clear.( you have to press it fast )
the machine will switch off and then press 14 then start.
the copier will reboot to its normal state.
Posted on May 13, 2008
Bubbabear64
  • 2794 Answers
SOURCE: H4 error message
Heat roller low detection error. The thermistor and lamp need to be checked. It could need a new fuser assembly.
Posted on Jun 12, 2008
SOURCE: H4 error on Sharp SF 7370
Low fuser temperature.....probably the heater lamp, possibly the fuse. You'll have a hard time getting either of these...and I wouldn't recommend spending any money on it anyway. I suggest it might be time to retire the old beast. Only a few hundred dollars these days to get a little Digital copier
Posted on Mar 12, 2009
FixinFax
  • 3085 Answers
SOURCE: SHARP AR C150 COPIER-ERROR MESSAGE H4-01
H means heat, you have a bad fuser.
Posted on Jan 28, 2010
When I open my copy machine is a Sharp AR-M355U on the screen appears a message saying code H4-01 What should I do?
H4 error is heat roller under temperature, try pressing the "#" key then "Interrupt" key then "C" key then "Interrupt" key to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-outs on the fuser unit or the fuser lamp is blown.
Jun 21, 2011 | Sharp AR-M350U Copier
Copier displays H4 error code and would not copy
detail for error code H4: Fusing section low temperature trouble
•The set temperature is not reached within the specified time (normally 3 min) when warming up or resetting from pre-heating. Cause:
  1. Cause thermistor trouble
  2. Heater lamp trouble
  3. Control PWB trouble
  4. Thermostat trouble
  5. AC power trouble
  6. Interlock switch trouble
Solution:
  • If the heater lamp blinks normally:
  1. Check the thermistor and its harness.
  2. Check the thermistor input circuit in the
  3. control PWB.
  • If the heater lamp does not light:
  1. Check for heater lamp disconnection and
  2. thermostat disconnection.
  3. Check the interlock switch.
  4. Check the AC PWB and the lamp control
  5. circuit in the control PWB.
good luck
Oct 13, 2010 | Sharp AL-1457 Black and White Copier
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Sep 20, 2010 | Sharp AR-275 Copier
Sharp a163 photocopier ero u2 40 and h4
U2 40 is a CRUM comunication error with the toner (wrong toner chip on toner cartridge or wrong toner cartridge) try a new toner.
H4 is a fuser trouble code. Check to make sure all conection are right, Theres a few posible problems for H4, power board, MCU board, thermistor, or broken heat lamp.
Aug 30, 2010 | Sharp AR-160 Copier
Im getting the code H4-00 need to fix it
Thermistor trouble
Heater lamp trouble
Control PWB trouble
Thermostat trouble
AC power trouble
Most likely problem is the thermistors.
Aug 16, 2010 | Sharp AR-M455N Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Jan 28, 2010 | Sharp AR-C150 Copier
HOW CAN RESET THE CALL SERVICE
Need to know what the call for service trouble code is. It will be displayed on the screen usually a letter then three numbers. example H4-00
Oct 13, 2009 | Sharp AR-M237 Copier
H4 error message
Jun 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Apr 28, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
99 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
