Question about Maytag Performa PAV2200
Maytag Performa washer dead.
Maytag Performa washer will not start. It won't agitate, drain, or spin. The only thing that is working is the water filling up the tub.
  • 868 Answers
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
My Performa PAVT920AWW washer will fill with water, but won't agitate. It will spin but has a funny burning smell.
might b motor fault or jammed gearbox.when motor turns one way it drains and spins, when it turns other way it agitates,might b jamming when it turns for agitate.try looking under unit and remove belt, then turn main drive pulley by hand clockwise then anticlock to see if it is jamming. turn power off first dont want any accidents.please reply to see how u go.good luck
Apr 08, 2010 | Maytag Performa PAV2200
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Have a ge washer, filss then does not progress to
May be a bad water level switch.
Open the control panel, with a full tub of water bump the water level switch with your hand. If it starts to agitate, replace the water level switch.
Mar 20, 2009 | Maytag Performa PAV2200
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
434 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
