Question about Acer AL1711 17" LCD Monitor
Acer L1711 I have a Acer AL1711 LCD monitor but there is a problem with the sound and I have tried to get it to work but it looks like the hardware has been deleted!
  • Acer Master
  • 5,568 Answers
Old request but . . . .
If you have the monitor connected and turned on, reboot the PC. It's possible that Windows will see both the monitor and sound capabilities and reinstall drivers for both.
Posted on Sep 18, 2008
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
HOW I CAN GET THE SERVICE MANUAL FOR THIS MONITORAL1711S
Hi follow the link , there is the manual for you.
Thanks Just Download it
http://www.devicemanuals.com/guide/Display%20and%20Video/Acer/Acer-AL1711-User%27s-Guide-TVRVeE16RT.html
Dec 29, 2009 | Acer AL1711 17" LCD Monitor
My Acer AL1711 LCD monitor blacks out every 2 seconds. I like to try to replace the capacitors in it as it has been tried by few people here successfully. To tri this I took the 4 screws off in the back of...
take a flathead screwdriver and place it anywhere where the front bezel and back, you can start on the top, bottom, or either side of the monitor, place your flathead screwdrier and place it in any part of the **** and twist your screwdriver, this should start releasing some of the clips. I had to do this with several dell lcd monitors to get into them. Keep in mind after this there will be more screws to take out to get the lcd out of there.
Aug 04, 2009 | Acer AL1711 17" Flat Panel LCD Monitor
Acer al1711
We have repaired a couple of these. R1 on board normally burnt also C6 and C22 bad on inverter board. Replace these and it will probably work. R1 is 10 ohm. Capacitors are 220uf 25v.
Nov 07, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Al1711 Problem....
White screen is normally a problem with the LCD panel,generally difficult to repair
Samir.
Oct 25, 2008 | Acer AL1711 17" LCD Monitor
Acer LCD AL1711 Monitor Flashes Colors
Main power supply, and or the backplane power supply, and or the backplane lamps usually cause this.
The fix is to try new modules using the process of illimination. Once the defective modules are determined, the new ones must stay in the monitor.
That is the process used to service this monitor.
Jerry G.
Jul 15, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
What is wrong with my AL1711
This is possibly an inverter. When the monitor goes out, examine the LCD to see if you can see a faint image of the video being displayed. IF so, replace inverter. If not, possibly a bad LCD or video circuitry.
Dec 07, 2007 | Acer AL1711 17" LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
HELP!! ACER AL1711 On and Off forever
Most of these have inverters that power the LCD monitor more than likey that is what happened! These can be repaired, but you will get charged an nominal amount. Better off getting a new one! You better get one soon, 17" monitors will soon be out, they will no longer be sold as the standard will soon be 19".
Nov 17, 2006 | Acer AL1711 17" Flat Panel LCD Monitor
Acer AL1711 17" LCD Monitor Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
