Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Craftsman lawn mower
I have a craftsman lawn mower with a wobbly right front wheel, how can i fix it? model #917.387280
  • Anonymous Mar 15, 2014
    What do I need to do so that I don't have to remove spark plug to stop mower from running
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 1,512 Answers
Hi judycdenn
You can get replacement wheels from most decent hardware stores, either with ball race bearings, or just plain old plastic bushes. they don't cost much, I would take in my old wheel to get one that fits.
But before you go buying spares for the mower... you should read this
regards
robotek
Posted on Apr 28, 2008
  • Graeme Ross
    Graeme Ross Jun 05, 2008
    Did you get a new wheel to fit in the end?
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How do I get the back wheel to stop wobbling and rubbing the side of the mower?
Hello. My guess is that if the wheel is not bent or broken around the spokes and is snug on axle, then you have a wheel bearing out. Simple to find and replace. Good luck.
Apr 01, 2016 | Craftsman Professional 775 Torque 175 cc...
How to remove drive wheels
Although I'm not familiar with this model, on some, you remove the center hub cap, and remove the bolt underneath. The wheel should slide right off.
Jun 23, 2015 | Craftsman 675 Series 190cc 22" Briggs ...
How to adjust left front wheel that wobbles
You will have to find a sleeve to fit or replace the wheel
Aug 09, 2014 | Craftsman Garden
675 series self-propelled - Front right wheel bearing assembly separated, wheel wobbles
I would take it back to the store and ask for warranty repairs since it is so new. That's ridiculous. If that doesn't work, try Sears Parts on-line or on the phone. They are better than most other manufactures.
Oct 12, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a Craftsman, front wheel drive mower. I have replaced the front (drive) wheels every 6 months for the last two years. The plastic gears on the wheels just get chewed up. What is the problem?
Must be a bad mower that got thru the assembly line somehow. I have owned a front wheel drive Craftsman mower for 7 yrs and have never had one single problem with anything on it.
Aug 24, 2012 | Craftsman Front Propelled Rear Bag Lawn...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Walk behind craftsman lawn mower. starts but shuts off after 15 minutes then will restart after it sits for 10 or 20 minutes
not sure what model but it sounds like it runs hot? make sure the fuel/oil mixture is correct, exhaust is not clogged, sparkplug is in good condition. hope this helps.
Jul 12, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,421 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
