Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 596.57587790 I have a Kenmore 596.57587790 refrigerator, the unit runs and gets to the right temp than it goes off, but after that it starts to defreeze. If I shut it down and turn if back on it starts again and does the same (gets to the temp and it goes off). I have notice when I turn it back on same times it does not work, it clicks off, but if I do it again it works. Any suggestions what could be causing this problem? And can I fix it?
  • 828 Answers
You have pinpointed your problem to the temperature control. Replacing the temperature control may very well solve your problem. A new temperature control ( cold control) can be ordered by your model number from the same place of purchase. If you are capable of removing the old control you can install the new one in reverse order.
Posted on Apr 29, 2008
Defreeze is not working or i donot know how keep in control to get ice cubes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Refrigerators
My kenmore side by side refrigerator/freezer isnt keeping food cold enough the fridge is at 50 degrees and the freezer is at 15 degrees. what should i do to reset it to see if that will bring up the temp?
heatman101
Aug 26, 2011 | Kenmore Refrigerators
Temp only goes down to 40 degrees everything runs
heatman101
Jul 05, 2011 | Kenmore 57029 Side by Side Refrigerator
Compressor goes off on overload. Replaced the overload relay,the ref. came down to temp. and would not restart. Installed a new start kit with overload and capacitor. Same results,came down in temp.but...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 23, 2011 | Kenmore 73503 Stainless Steel Bottom...
Fridge side works fine freezer side keeps running no matter were you set the temp -10 -20 degrees sounds like the fridge is running all the time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 06, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Freeze running continualy to maintain temp
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Oct 08, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
The day before yesterday my unit star defreezing yesterday the unit was runing some kind of motor running but it does not freeze. Will it need freon or any kind of liquid? A technician says it is the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
Temp. going up
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
heatman101
Aug 31, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore cold spot side by side Model 106.41512101 My freezer defreezes often. Ice cubes melt, etc. What causes this and how can I resolve the problem ?
all refrigerators use a timer circuit to temporarily turn on heating coils in your freezer side. It also has a round sensor hooked to the coils that senses the internal temp so it does not over heat. It sound like this sensor is bad or your timer is at fault. This sensor is located in the freezor box you have to remove the inside metal/plastic back to get at it you will see wires they will run to a black tube or clear glass tube that is the heating element the sensor is on one of the wires going to the heater and it will be clipped onto a freon line of the condenser close to the heater. You can test it by putting it in a glass of ice and allowing the ice to melt to make water and the unit can be tested with an ohm meter. It should show low ohms close to zero very close and when heated up just run it under your faucet it should show hi ohms this is just an on off switch that uses temp to turn on and off.
Aug 08, 2010 | Kenmore Refrigerators
Freezer temp
No, these fluctuations are a sign of a unstable control unit. test the control unit for its operational value and , replace the thermostats as well.
May 22, 2009 | Kenmore 64722 Top Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
