Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
FreeAgent Go My boss bought a FreeAgent Go to backup his laptop information. He plugged it in and it worked fine. He transfered a few files over, but now when I plug it in, it says it is an unknown device. I took it home over the weekend and plugged it into my PC and I could open everything fine. But no matter how many times I restart this laptop I can't get it to work. Also, when I plug it into the computer it spins and the light comes on, but shortly after everything shuts down. When I plug it into the USB hub he has the hard drive makes a high pitch clicking/beeping noise (really annoying). I am not sure what to do. I have contacted Seagate, but they weren't any help. Any ideas would be great! Tracy
The beeping means that not enough power is being supplied to the device, and as a result, the disc will not spin up (not recognized). I suspect that the reason he was able to once make it work is perhaps he has more USB devices plugged in now...therefore, not enough power to go around. Or perhaps he has swapped cables?? I had this exact same issue when I bought a new cable for my Freeagent Go. I wanted a longer cable, but for whatever reason the cable itself didn't supply enough power; I got that ugly sounding beep (could have been a bad cable I suppose). When I plugged the drive in using my old cable, it worked flawlessly. I would first ask him if he has been plugging in more devices recently. Then I'd get a compatible USB cable that has an extra power connection (when he plugs it in, he'll have to plug into 2 USB ports).
Hope this helps.
-Paul
Posted on Feb 23, 2009
  • 3 Answers
Hey, had a very similar problem with mine, got the data off it in the end. posted explanation and photo's here:
http://www.moneywhatmoney.co.uk/index.php/Bens-Articles/Seagate-from-the-Ashes.html
Posted on Jun 06, 2008
How do i transfer my files from my freeagent goflex to my new computer
Plug in the hard drive and then go to "My Computer" look for your "freeagent " icon and open it.You should be able to right click(highlight) the folders you wish to copyfrom it, and drag them into a new folder on your desktop
Oct 17, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
Hi, I bought a Seagate GoFlex a couple of days ago and successfully backed up my Mac at home. However, when I went to use the GoFlex on my PC at university, the PC was not reading the goflex. Thanks.
Did you reformat the FreeAgent drive when you backed up the Mac? If you use Time Machine or other backup software for the Mac, you had to reformat the drive. If you want the PC to read the disc, it must be formatted in a FAT32 or NTFS file system. The Mac OS formats discs in the HFS+ (extended hard drive format) system.
Unfortunately, if you reformat the disc to a Windows compatible format, you will lose your current backup. The drive will be as a large media transfer disc but not for the backup images. This site, http://www.cs.ubc.ca/~pcarbo/macnexstar.html , has information on splitting the hard drive into two partitions, one HFS+ and one FAT32. Then you could have your backup on one part of the GoFlex and still transfer files from the Mac to the PC and vice versa.
I hope this helps.
May 18, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
My Seagate FreeAgent Go250GB become write protected for Macbook, but works fine on windows laptop. How can I fix this issue?
It's probably formatted to the wrong filesystem; Macs prefer HFS+, Windows prefers NTFS, but they both can read and write FAT32. I'd recommend using the Mac's Disk Utility application to reformat the drive to be FAT 32 (but be careful, this will erase the external hard drive, so back up first!)
Apr 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How do I work on my data on the Seagate FreeAgent 2TB GoFlex Desktop USB 2.0 Hard Drive as my computer memory is at capacity. I want to be able to use my external hard drive as an extension of my computer...
Assuming you are using a Windows operating system, you can just plug it into your computer's USB ports, and the computer will recognise it as another hard drive.
Instructions:
Double-click on 'My Computer' and take note of what drive letters are there (C:, D:, etc.) before you plug in the Seagate Freeagent.
Plug in the Seagate Freeagent. You'll see the new drive, likely E: or F: (depending on what is already there before you plugged in the Seagate Freeagent)
Double-click on the new drive, and it'll open up and you'll see the files stored on that drive. You can drag and drop files and save to this drive like any other folder on your computer.
Mar 06, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Seagate freeagent go 250 gb. was working fine for
which files.... if you have "show system files" selected in your folder options in your operating system it still won't let you open them as that is it's way of preventing you from deleting or changing them
Jul 13, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I am trying to extract my backed up files from my Seagate FreeAgent go....but not sure how to..I don't see a restore option under backup on the Seagate Manager as the instructions say.
The only time I have seen this error, no backup was ever performed (or the program lost the information regarding existing backups). Try looking at the backup log (Seagate Manager > View Backup Log) to see what backups should exist.
I hope this gives you a starting place and wish that I could be more help.
Mar 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Sound and vibration from the hard disk [seagate freeagent500gb]
If its under warranty, it probably wouldnt hurt to contact Seagate; though, if its not heating up, and it seems to be working fine, you probably don't need to do anything.
Jan 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can't erase files on Seagate FreeAgent Go
Under the Gear looking icon located on each window, there will be a delte option. Just click what you would like to delete, click the icon and press delete.
Let me know if this works.
Dec 02, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent external hard drive 500GB not recognising directory tree
Its the rubbish software that Seagate have bundled with their drive which will not allow you to backup the system folders. Solution is to use another backup utility, a google search will quickly locate numerous FREE software products which will alow you to copy anything. Unfortunately when you start googling about this drive you may be quite distressed about your purchase, as i have been :( Problems lay ahead with this drive due to inadequate cooling.....
Jun 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
3,295 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
