Question about Hoover H120M Front Load Washer / Dryer
Six express hoover washing machine
My washin machine doesnt heat the water at the required temperature, i just got the machine, i dont know which button should i press to get the water heated. The washing machine is connected to cold water only, is not possible to connect it to hot water too. Please, help me with this problem if u can. Thanks in advance!
  • Elfenwing May 22, 2008
    the machine fills with a little water initially, turns twice, then stops completely. The temperature is set to 30 degrees.
I fixed it, allright, by returning the washing machine back to the store. Thanks anyway.
Posted on Apr 29, 2008
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Nov 30, 2015 | Hoover Washing Machines
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Washing machine not heating water
Washin machines "do not" have heating devices, make sure to check your water heater and turn it back on to get your water heated.
That will get you back in hot water business.
GOOD LUCK.
Aug 30, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Hoover six express wont spin
all hoover machines spin in a clockwise direction the fact that you say the machine only washes in an anti-clockwise direction is a good indication that the reversing switches have failed (these provide the switching to drive the motor in either direction) if your machine uses a mechanical type programme timer this has failed if it it is a processor controlled machine it will be the motor drive card will need to be replaced either way not a diy task
Apr 21, 2008 | Washing Machines
LG WFT7030TP
Trouble shooting a washing machine is easy but you have to know the sistem first if the washine machine take water wwell but dont do nothing eals could be a couple of things. The water level switch send curent to the water selenoids when the maching is empty then when the level of water reach the selected level the presure of the water active a presure swithc and the curent go to the timer there the timer send the curent to the motor, as you can see there are a procedure that you have to know to repair a washin machine and some instrument to trace continuity and curent warning disconect the machine frome ac outlet befor service .....good luck and rate me if you survive this riskey adventure...
Feb 17, 2008 | Washing Machines
Manual
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Oct 05, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Aug 14, 2007 | Hoover AL130 Front Load Washer
Water won't stop heating up
You should replace the thermostat (it doesn't stop current to the heating element in the temp it should). Good luck!
Oct 15, 2006 | Hoover AL130 Front Load Washer
Hoover H120M Front Load Washer / Dryer Logo
129 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
