Question about HP DeskJet 5150 InkJet Printer
Ink cartridge problems
I exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
HELP!
  • Anonymous May 28, 2008
    Our HP DeskJet 5150 says it is out of yellow. At first it would still print in black only but now it will not print. We have put a new cartridge in, we have turned the printer and the computer off and on. One other time the third yellow new cartridge that we installed worked for awhile but now the yellow light is blinking.
  • 121 Answers
Since the black ink cartige is working then its obvious that the problem is in the other cartige ... the colored cartige could be installed un properly. try to take it out and install it again.
Posted on May 28, 2008
The printer is working again - I exchanged the ink cartridges yet again, and finally the printer accepted them. Still don't know why the problem developed.
Posted on Apr 29, 2008
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
The black ink doesn't print. We have brother cartridges in our printer DCP 385C, and until recently it always told us when ink was running out. now it doesn't print the black ink at all and it doesn't tell...
Make sure the protective tape covering the new cartridge has been COMPLETELY removed then reinsert. Your printer should tell you that a new cartridge is inserted and ask to print a test page, align etc. Otherwise your cartridge may have a faulty chip which simply wont read.
In which case you need to return it and get a replacement.
Mar 07, 2010 | Brother DCP-385C Stylish Colour Inkjet...
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though...
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Jul 07, 2008 | HP Office Equipment & Supplies
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Black ink not printing
Having had the same problem on my 425cn Brother with the black ink, I'm told that the solution is hot water. I goes something like this: remove cartridge, place in container with hot water for a while, remove allow to dry completely, replace, perform clean cycle and print test page. Apparently it's imperative to dry completely and stand cartridge upright. The warm water thins the ink, and remove (apparently) blockages. I cannot verify that this works, but will try it this weekend and let you know! If the housing that the ink cartridge can be readily removed, take that out and clean in warm water. Again dry very well before returning. Be care full that ink becomes runny and may leak out of cartridge and make a mess - so work carefully.
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Misrepresented product?
No manufacturing process is flawless. These things happen. Return to staples for an exchange. Most managers will exchange ink even after the 14 days. If they dont, then buy new ones and recycle the nonworking ones for $3 on your rewards statement. I have seen people come back the same day after they bought a brand new HP ink cartrige beucase it does not work. Its not that they had the wrong cartridge, its just that it was a bad one.
Dec 07, 2007 | HP 56&57 Inkjet Cartridge Combo 3-pack...
HP DeskJet 5150 InkJet Printer Logo
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
