Question about Rangemaster Proffessional 110 Gas Kitchen Range
Ignition on gas hob fails sometimes on certains burners
The ignition will always spark on the 2 burners on the left, however for the 2 burners on the right, there will be a spark when the left burners are ignited but will not otherwise. Power must be getting to the spark system and they the parts must be ok too if they work sometimes. Could it be dirt clogging something or something else?
Thanks,
Barry
  • bazwaldo Sep 08, 2008
    Thanks for the suggestion. I managed to solve this problem by removing the hub covers and pulling out the little ceramic sparkers. First I raised it a little and replaced the cover. And it sparked, so using a pliers I tugged the inner metal rod out a little further from the ceramic holder so that the tip of it would be closer to the cover. Put everything back in place and it worked. The gap must have been too much for the spark to travel for some reason.
  • Anonymous Sep 29, 2008
    Spark ignition on gas hob has failed completly. No spark at any of the 4 rings.
Open the hob covers with a screw driver and check the wires that carry the spark are intact and haven't been chewed by a rodent ie (RAT/MOUSE) like my one had been :-)
Posted on Sep 07, 2008
Stoves sterling 1100DF hob burners will not ignite there is no spark to any burner. Gas flows as normal.
More than likely the spark module has malfunctioned and needs to be replaced.
Apr 23, 2012 | Stoves Kitchen Ranges
Ignition on hob not sparking
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Belling Solitaire G747 Gas Kitchen Range
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Mar 07, 2011 | Ovens
Gas hob keeps sparking all the time
check the ignition button or its wiring, the button may be broken and 'on' all the time, or the wires underneath broken off and shorted together.
Jan 18, 2011 | Rangemaster Professional 4 Burner Hob 23...
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Jan 04, 2009 | Cooktops
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Rangemaster Proffessional 110 Gas Kitchen Range Logo
1,561 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
