Face plate How can I touch up a scratch on my fpb-600 faceplate? the center black edge. Thanks,
    Sergeant:
    Champion:
  • 319 Answers
You could use fine steel wool to smooth out scratches. If the original finish was glossy, spray plate with light coats of clear acrylate
Posted on Apr 29, 2008
Faceplate display only functions when you touch a knob or button
THE FACEPLATE HAS LIKE SOME PINS WHERE IT MAKES CONTACT THE FACE PLATE WITH THE STEREO BODY WITH A COTTON AND SOME ALCOHOL CLEAN THE CONECTOR THE ONES THAT ARE IN THE STEREO BODY AND THE FACE PLATE BUT WHEN YOU MAKE IT MAKE SURE THE CAR OR FACE ITS TURN OFF
Nov 02, 2013 | Alpine CDA-9831 CD Player
I have a Kohler Overflow tub with a faceplate covering the screws that would allow me to get to the trip lever...the lever must be stuck "down" because the tub won't drain. How do I take off...
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
May 19, 2011 | Kohler Archer Clearflo 1-1/2in Bath Drain...
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
My Alpine CDA-9835 has a short in face plate, plays music but unable to change tracks, display goes black, and usually have to remove faceplate and re seat over and over till it comes back on usually...
most of the time you have to send the faceplate into the manufacters repair dept or a factory authorized repair center will most likely need the entire radio/ unit to repair the faceplate problems
Good Luck!!!
Larry Dillon
Aug 26, 2009 | Alpine CDA-9835 CD Player
My outer face plate on the gz one is scratched up can it be repla
You can buy the face plate from:
http://www.1800mobiles.com/verizon-gzone-boulder-accessories.html
Dec 06, 2008 | Casio G''zOne Type S Cellular Phone
SRC button on faceplate doesn't work
yup. that can be a reason.
use a new one and check it.
Jul 22, 2008 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
How to remove center console faceplate?
after looking around the edges for small screws gently start prying around the edges at the corners first. the best option is to have your new cover plate in hand and u will see exactly where the snap clips are at and then you can "Gently" pry at those spots with a flat screwdriver to pop it off with
Jul 19, 2008 | 2005 Chevrolet Equinox
GARMIN STREET PILOT 320
To unlock a “frozen unit,
1. power it off
2. Remove the face plate, Gently pry on the face plane. In the center top edge (under the Garmin logo) you’ll see a small notch.
3. on the right side of the unit, press the reset button.
4. replace the face plate
5. Power it back up.
The unit should restart normally.
Mar 21, 2008 | GPS
Psp joystick problems
try powering off the system, then power on while not touching the controls at all. it may be realigning at power up and if it is off center it will think that is the center.
Jan 24, 2008 | Sony ACY-BR81/OB
How do I remove the face plate from my C330 GPS?
The face plate is removed by inserting your fingernail under the silver plate in the center top of faceplate.It pulls out quite easily. Rob
Sep 17, 2007 | Garmin StreetPilot C330 GPS Receiver
 Grubhead
Grubhead
