Question about E-Machines eMachines Desktop PC
Dell CPU Trouble
The Dell cpu that i have is currently having problems loading Windows XP. This is the operating system that came with the compuer. However everytime I turn the computer on it starts to boot fine until I get to the page that says (Windows XP Now Loading) and then ti freezes up and will not go any further. I have tried to restart it sveral times and even ran system test but no problems are acknowledged. Could you please assist me with this problem at your earliest convience. I have tried the same solution that you gave me for the other computer but it will not work for the dell cpu.Thanks in advance for your help once again....
    Genius:
  • 1,027 Answers
I have DELL recovery CD's for different systems. If you want a copy I can mail them to you. The one for WinXP does not have the VLKey the one for XPPro does. If interested send contact info to mewms_14904@verizon.net.
Besides that I have a Boot cd that can run virus scan in a boot dos shell. LINK
This is an iso file. download and burn onto cd boot from this and run anti-virus.
Posted on Apr 28, 2008
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Dell studio XPS 7100 tower. the power light is orange and it wont start
The amber light can mean that the power supply isn't providing enough power to the system board or that the system board (or the CPU on the board) isn't working.
Since your fans are working, your power supply hasn't completely failed and the board is providing power to the system fans. Thus, either the power supply is giving limited power, your CPU has failed or the motherboard isn't talking to the CPU anymore. (The BIOS is only accessible when the CPU is operational.) I'd first try a new power supply. Make sure to get one that has at least the same power rating as the original, matches the wiring in your case and will fit in your case. (Note: you need to be careful. 1) Some Dell systems use a proprietary power supply (shape and wiring). 2) Many current power supplies are rated by their peak power output, not their stable power output. You want to match or exceed the stable power output of the current power supply.)
If the power supply doesn't solve the problem, I suggest getting a new computer is better than a new CPU or motherboard. (The Dell Studio XPS 7100 was released in 2010.) Replacing the CPU or the motherboard makes your computer a new machine to Microsoft and you may have trouble getting a working license. (You'd have to call Microsoft for activation and they probably will want to charge you for a new license.) Take your hard drive out of the current machine to get your data from it. You can put the drive inside another desktop with SATA ports, use an external drive enclosure (3.5") or SATA drive dock, or a USB to SATA drive adapter.
I hope this helps.
Dec 28, 2013 | Dell Studio Xps 7100 Desktop Computer (AMD...
XPS 410 won't boot but CPU fan spins
A loud CPU fan will also equate with overheating and imminent failure. Can you reliably access your system BIOS? Can you run a memory test there? If so your CPU is functional (and your memory which is also subject to overheating and BSOD under XP. If those are good your prime suspect is your HDD. If you can afford it, now would be a good time to replace your system.
Jan 09, 2013 | Dell XPS Computers & Internet
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
Windows XP won't load - black screen
Refresh all the connection on your motherboard like ATX power supply, HDD and CD/DVD ROM cables, and specially the RAM. You may have to clean the RAM as shown in the image below. c4d62f6.jpg
then hopefully your computer will return to normal. Hope this helps.
Sep 24, 2009 | Dell OptiPlex GX280 PC Desktop
Computer will reboot on Virus/Spyware scan at random. I have: 1. Installed clean XP SP2 parallel system and booted that one. Same problem. 2. Memory Test at boot time is OK. 3. Air circulation from Power...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
Sep 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blu-ray problems from blu-ray computer drive.
Vista takes significantly more procesing power from your CPU than XP did. The colored squares, or pixellation, are a result of your computer's processor having a bit of trouble keeping up with the demands of the Blu Ray video. To resolve this, you can do several things: Upgrade your CPU(You can upgrade the the highest CPU your current motherboard will allow) Upgrade your RAM, (RAM is fairly cheap for the bang you get and will be the cheapest upgrade option.) Max it out if you can. Reinstall XP back on your computer. (Cheapest option, period). This time, use Ghost or some other imaging program to image your Hard Drive once you get it working correctly so that you can recover in minutes as opposed to reformat-reinstall next time.
Jul 10, 2008 | Computers & Internet
Emachine trouble
There are several causes that are common.
The first,especially with e-machines, is they do not like service pack 2 updates.
If you have a standard winxp cd you can boot from that and choose repair console once the cd starts to load win xp files.
First, I would attempt to load windows by as it boots, press F8 to go into options, select first LAST KNOWN GOOD Configuration
If that doesn't work then select SAFE MODE.
If you can get in in the SAFE MODE, select ADMINISTRATOR
no password and try and undo changes that were made.
Apr 24, 2008 | E-Machines eMachines Desktop PC
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
I INSTALLED MODEL T-S461-HSB TO MY WINDOWS XP AND IT STILL DON'T WRITE OR SHOW THE SIGNATURE THATS BEING WRITTEN DOWN. CAN YOU PLEASE TELL ME WHAT I'M DOING WRONG.
you download the software eapp for using the signature pads here is the minimum requirements of install eapp software
The eApp software was designed to function on both laptop and tablet PC computers.
Below are the hardware/software requirements for each configuration.
Note: eApp should run under Windows 2000, Windows XP Home and Media Center versions but Windows XP Professional (32 bit) and Windows Vista (32 bit) are the only 2 operating systems that the eApp help desk currently support. Use of an unsupported operating system can inhibit your ability to use eApp as it was intended and cause extra 3rd party support expenses.
Laptop -
Minimum Requirements:
1.2 GHz CPU or faster
512 MB Ram
20 GB Hard drive
Windows Vista
Recommended Requirements:
1.7 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash
Firewall and Virus protection software -
Any third-party protection software will do. Firewall and virus protection software should be running at all times to insure that your computer is not compromised and that customer information is not stolen. In the event of a system error you may be asked to provide the help desk with the results of a current virus scan to insure your machine is functioning properly. Failure to provide the scan results may result in a delay in resolving the problem.
Signature Capture Pad - Topaz SigLite Slim 1x5
Tablet PC -
512 MB Ram
20 GB Hard drive
Windows Vista
1.5 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash Drive
Tablet PC Signature Capture Software -
Topaz Tablet PC Software $100.00 USD
A signature capture pad is NOT required but special software is needed for the Tablet PC.
Mar 14, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
