Question about Honeywell Programmable Thermostat Heater
Reset Furnace filter replacement/battery light
Honeywell 5/2 Programmable Replacement Thermostat var prodBrand = 'Honeywell'; Sears item# 03245277000 var omEvt="prodView,event10";var omPrds=";03245277000P"; Mfr. model# YRTH230B1009
Hello, We have the 5/2 Honeywell Programmable thermostat, and I would like to know how to reset the furnace filter reminder and flashing battery indicator. If memory serves me right, there is no battery for this unit, why is my light flashing? The digital indicator displays a flashing AAA like battery that is in two pieces?
Can you help ?
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Posted on Mar 07, 2008
  • 137 Answers
SOURCE: Honeywell programmable Thermostat won't hold time or program
Most thermostats use a six volt transformer for a power source, similar to a door bell, you can tell if yours does by looking at the wires that are attached to the thermostat.
The wires will be thin with just a single strand if you have these wires then you have a transformer, try and find the transformer (good luck) test it with a voltmeter if it fails the test that's it, if not, call the man. Probably it though.
Posted on Feb 15, 2009
  • 13 Answers
SOURCE: batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on
Posted on Feb 02, 2010
  • 1515 Answers
SOURCE: Our Honeywell programmable thermostat is
Good Morning, and yes you said it. Anytime a stat doesn't come on when it is set for a call for heat or cooling, the sensor on the subbase of the stat has lost its ability to sense the correct temperature. I have seen mechanical stats last as long as 25 plus years, but that's truly amazing for a digital stat to last that long. Yes, replace the thermostat. I don't know what kind of system you have, but if its a gas furnace with an a/c, the wiring will look like this. You will have terminals marked R, Red, for the 24 volt hot wire, G, Green, Y, Yellow, and W, White for heat. Going back to the red wire, it should have RC and RH on it. There will be a normally red wire connecting the 2 terminals.The Red wire coming in can connect to either one, as they are all together. The new stat will come with the new Red jumper wire attached. So, if you do have a gas heater, this is very easy to install. The only terminals you will need to use are RH to RC for the incoming red, Y, G, and W for heat. Y is for cool, and G is for fan. Very easy. Now if you have a heat-pump, they have many more terminals and can be a problem wiring them. If you have gas, forget the heat pump. I wont confuse you by going there. If it is a heat-pump, contact me in the comment box to let me know, and I can help you there also. Get a new stat at Home Depot, Lowe's Hardware, or O.S. Hardware. You want a 5 day, 2 day programmable Heating and cooling thermostat, 24 volts.It will have everything you need. See if it takes batteries for the display, they may not come with those, it will say on the box. Turn off your power to heater, so you won't short out the new one.They come in 2 sections, first the stat that just snaps on, and the subbase that is screwed to the wall. It will have the wiring terminals on it. Remove a couple of screws and loosen wires and remove. Be sure you write down how the wires go in case they used different colors, you never know. You will be all set. Store the manual in a safe place for future use. I wish you the best.
A/C, Heating, & Refrigeration Contractor.
PS, Please rate me on this :))
Happy Holidays to you and family!
Posted on Nov 23, 2010
Testimonial: "I hate spending money needlessly replacing items that may not be the problem. Thank you for confirming my suspicions."
  • 5306 Answers
SOURCE: thermostat won't keep furnace fan running
You probably have a loose or broken wire to the fan relay. Check the wires on the thermostat first. Pull up on the bottom of the thermostat to remove it from the wall plate. You should see several screw terminals and the conductor wires that should be connected to them when you look at the wall plate. Check if any of the wires are disconnected or broken. If a wire is broken, strip a portion of the unbroken section of the wire and secure it to the appropriate screw. (The fan relay terminal is G for most setups.) If none of the wires are loose or broken, then you have to check for damage to the wires between your heating system and the thermostat or at the heating system. It could be a bad wire going to the jumper on control board or damage to the board itself.
I hope this helps. If the problem is not at the thermostat, you may need to have a professional diagnose and fix the problem. However, if you post additional comments about your heating system, Fixya experts may be able to help you diagnose the problem.
(we had the broken wires at the thermostat keeping the fan from working in the past. It's an easy fix if you are willing to handle small wires carefully.)
Posted on Jul 06, 2013
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
pknab, I have the same problem. And it comes down a few things: 1) the flashing 1:00 indicates that you've lost power, and the system needs to be reset. 2) Reset means taking out the batteries for longer than 5 minutes. 3) You have to change your filter monthly. There's one in the cold air return and another one in the furnace. If you don't, your FURNACE may be causing number one (my conjecture). 4) We had an electrical storm 2 days ago--nothing else in the house lost its sense of time...but...well...the online operating manual is difficult to find try or (but it doesn't tell us this stuff...I'm still looking for the meaning of the EEE in the display..perhaps I have repowered the thermostat/furnace in the wrong order).
Dec 07, 2010 | Honeywell Programmable Thermostat Heater
My furnace has stopped working. the thermostat (Honeywell Chromotherm III) displays HOLD - AC. What does this mean? I replaced the batteries but nothing has changed.
Try to find a reset button or just change out the thermostat. I'm guessing you don't have the manual. Thats a pretty old model, I think you have to set the time and day before you can use the thermostat.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
My Model TH8320U1008 touchscreen not working. I have replaced the batteries, still doesn't work. Is there a way to reset it?
I dont think its your thermostat. The 8000 pro series is relatively new. I think is you furnace you lost 24 Volt power. Check the furnace out first.
Oct 18, 2009 | Honeywell Electronic Programmable...
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Digtal thermostates
Give this number a call if you are in the US, 800-341-0110. You will need the COMPLETE model number not just 230B. Something like YRTH230B1009. They can link you a manual via email.
Nov 13, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
363 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
